Summary
These messages indicate that the AppArmor subsystem is (re)loading profile(s) that define the AppArmor security policy. This happens normally during system startup, or if you restart the apparmor.service unit.
They do not indicate something being allowed or denied by AppArmor. They indicate the policy (which defines the rules for allow/deny) has been (re)loaded.
Gory Details
Audit Leader
audit: type=1400 audit(1473854574.089:114):
The audit: prefix means it is coming from the kernel's audit subsystem, which is used by both SELinux and AppArmor. In the context of computer security, "auditing" usually means "logging". (Because logs allow things that happen on a system to be audited. The terminology is overloaded.)
type=1400 is event type code. 1400 is AUDIT_AVC, "SE Linux avc denial or grant". While AppArmor works to replace SELinux as far as the operator-facing portions are concerned, it is implemented on top of some of the SELinux primitives. As a result, most/all AppArmor messages get logged using this code.
audit(1473854574.089:114) provides a timestamp and an event ID.
The timestamp uses the standard Unix format of "seconds since 1970 January 01 at 00:00:00 UTC". You can decode it with the GNU date(1) utility. For example:
$ date -d '@1473854574.089'
Wed Sep 14 08:02:54 EDT 2016
The event ID is basically just a sequence number, starting at one (not zero) at system boot. It is allegedly possible for multiple log lines to reference the same event ID, if they are all part of the same transaction.
AppArmor Leader
apparmor="STATUS" operation="profile_replace"
apparmor=STATUS indicates this is an AppArmor message (as opposed to a proper SELinux message). The type of AppArmor message here is a status report, i.e., something about the AppArmor system as a whole -- and not about a permissions decision. Those get logged with ALLOWED or DENIED.
operation indicates the operation that triggered the AppArmor audit log message. profile_replace means that a profile definition in the kernel is being replaced with a new one. For normal operations, these are things like open or write.
AppArmor Entities
profile="unconfined" name="/usr/lib/cups/backend/cups-pdf"
An AppArmor profile is a set of rules that get applied in particular circumstances. profile=unconfined means the process that triggered this event is not confined by any AppArmor profile. No profile apples. No AppArmor rules apply. This makes sense, since most restrictions would block a profile_reload.
name tells us the name of the object associated with this event. Here, object is used in the grammatical sense: This is the thing being acted upon. Since this is a profile_replace operation, this is the profile being replaced.
AppArmor profiles are traditionally named using the full path of the executable. When looking for the profile definition file, slashes (/) get replaced with dots (.) . So the corresponding profile is /etc/apparmor.d/usr.lib.cups.backend.cups-pdf.
Process Details
pid=31430 comm="apparmor_parser"
Process ID 31430 performed the profile_replace operation. The name of the command associated with that process was apparmor_parser. apparmor_parser is the name of the program that loads AppArmor profiles into the kernel.
References
https://manpages.ubuntu.com/manpages/en/man7/apparmor.7.html
https://manpages.ubuntu.com/manpages/en/man5/apparmor.d.5.html
https://manpages.ubuntu.com/manpages/en/man8/apparmor_parser.8.html
https://github.com/torvalds/linux/blob/master/include/uapi/linux/audit.h
https://github.com/linux-audit/audit-documentation/blob/main/specs/fields/field-dictionary.csv
https://wiki.ubuntu.com/DebuggingApparmor#Debugging_procedure
https://wiki.debian.org/AppArmor/HowToUse#Diagnose_if_a_bug_might_have_been_caused_by_AppArmor
