Installed Ubuntu 16.04 in Parallels 11 on Macbook Pro Retina.
If during the installation I select "Try Ubuntu Without Installing" the display resolution is fine and xrandr shows resolutions of 640x480 up to 1920x1200 - it selects 1920x1200 - looks ok.
From this desktop I then select "Install Ubuntu 16.04.1 LTS" and proceed with the install. It installs fine.
After re-launching the display is now stuck at 800x600. xrandr says Failed to get size of gamma for output default. And the only resolution it shows is 800x600 - too low.
When I launched Additional Drivers it found 1 unknown one but said it was not working. Did not find an Nvidia driver.
The computer uses an Nvidia GEForce GT 650M chip.
Any suggestions? I know there are other similar posts but am stumped.
Thanks
5 Answers5
I used the work-around in
Stuck at 800x600 display resolution Ubuntu 14
This increases the resolution to an acceptable level (2560x1440) by editing /etc/default/grub - changing to GRUB_GFXMODE 2560x1440.
However, I feel that the Nvidia driver is not installed properly so this is just a work-around...
You have to update grub too. After some updates on 16.04 (on Parallels) I've lost my display settings. That helps me:
sudo vim /etc/default/grub
GRUB_GFXMODE=1440x900     # MacBookAir resolution
sudo update-grub
Try to disable secure boot, you will get back all resolution of display as before installation of Nvidia driver. As it works
You could try switching to proprietary drivers. For example, I have GTX 1650 and for it to work properly I had to install proprietary drivers. Ubuntu allows doing this quite easy:
  1. Search for Additinol Drivers applicaton in Activities search fieldenter image description here
  2. Choose the driver you need and click on Apply Changes enter image description here
prnsml
  • 113
What worked for me was switching my Nvidia drivers from 470 to 450 (based on rogergo's comment).
Sam
  • 109
