Originally, there was Windows 7 installed on a laptop that I was given by my employer to work on. I installed Ubuntu 15.04 next to Windows using bootable USB. Recently, I have received permission to delete Windows, so I used gparted and formatted the partition with Windows to ext4. Now, when I start the laptop, I get "Invalid partition table" message. After pressing any key, Ubuntu normally boots up and I can see no other problems.
Do you know how to deal with Invalid partition table error?
Edit#1
I made a mistake - it's Ubuntu 15.04, not 14.04. I tried installing boot-repair but it seems that there is none for Ubuntu 15.04.
The output of sudo gdisk -l /dev/sda:
GPT fdisk (gdisk) version 0.8.10
Partition table scan:
MBR: MBR only
BSD: not present
APM: not present
GPT: not present
Found invalid GPT and valid MBR; converting MBR to GPT format
in memory.
Disk /dev/sda: 500118192 sectors, 238.5 GiB
Logical sector size: 512 bytes
Disk identifier (GUID): 921B3CFE-5AE9-4D20-A006-8212D26F78EC
Partition table holds up to 128 entries
First usable sector is 34, last usable sector is 500118158
Partitions will be aligned on 2048-sector boundaries
Total free space is 5932 sectors (2.9 MiB)
Number Start (sector) End (sector) Size Code Name
1 2048 224854848 107.2 GiB 8300 Linux filesystem
5 224856064 483569663 123.4 GiB 8300 Linux filesystem
6 483571712 500117503 7.9 GiB 8200 Linux swap
Edit#2
I upgraded Ubuntu to 16.04 LTS and ran boot-repair, but it didn't help. The report can be found here: http://paste2.org/wGJCdmaZ. Boot-repair also mentioned:
The boot files of [The OS now in use - Ubuntu 16.04 LTS] are far from the start of the disk. Your BIOS may not detect them. You may want to retry after creating a /boot partition (EXT4, >200MB, start of the disk). This can be performed via tools such as gParted. Then select this partition via the [Separate /boot partition:] option of [Boot Repair]. (https://help.ubuntu.com/community/BootPartition)
But as Ubuntu eventually boots up correctly, can it be a problem?
