I want to make sure when my pc starts up, it boots into tty1, instead of tty7. And also, in case I need it, I should also be able to switch to the graphical desktop using ctrl +alt+f7 in case I need it. How do I do that?
twodee
  • 232
Find GRUB_CMDLINE_LINUX_DEFAULT in /etc/default/grub (with a sudo nano /etc/default/grub and change it to ...
GRUB_CMDLINE_LINUX_DEFAULT="text"
and update grub with ...
sudo update-grub
Tell systemd to not load the desktop with ...
sudo systemctl enable multi-user.target --force
sudo systemctl set-default multi-user.target
And the initial boot will end up on a tty. By default it will be tty1. You can still go to the desktop by using the command startx on commandline.
You will need to issue the sudo systemctl start lightdm command before using control+alt+f7. Probably impossible to get around that: if a desktop is loaded during boot it will take precedence.
Rinzwind
  • 309,379
