Problem in sudo apt-get update
Hit archive.ubuntu.com vivid InRelease
Hit archive.ubuntu.com vivid/universe amd64 Packages
Hit archive.ubuntu.com vivid/universe i386 Packages
Hit archive.ubuntu.com vivid/universe Translation-en
Ign ftp://gb.archive.ubuntu.com edgy InRelease
Err gb.archive.ubuntu.com edgy Release.gpg
  Connection timeout
Ign gb.archive.ubuntu.com edgy Release
100% [Logging in]
It is stuck at logging in 100%.
still there is some problem in edgy release
Ign http://old-releases.ubuntu.com vivid InRelease
Ign http://old-releases.ubuntu.com vivid Release.gpg
Ign old-releases.ubuntu.com vivid Release
Err old-releases.ubuntu.com vivid/universe amd64 Packages
  404  Not Found
Err //old-releases.ubuntu.com vivid/universe i386 Packages
  404  Not Found
Ign ://old-releases.ubuntu.com vivid/universe Translation-en_IN
Ign old-releases.ubuntu.com edgy InRelease
Err old-releases.ubuntu.com edgy Release.gpg
  Connection timeout
Ign old-releases.ubuntu.com edgy Release
24% [Logging in]
Edit your /etc/apt/sources.list/ and comment out all of the lines that contain either vivid or edgy by inserting a # character at the beginning of each of the lines. These lines don't make any sense, since edgy (6.10) and vivid (15.04) can't match with your version of Ubuntu, which is trusty (14.04).
  1. From the terminal run the following command to edit /etc/apt/sources.list/ with nano text editor:
    sudo nano /etc/apt/sources.list
    The instructions for using nano editor are always found at the bottom of every page. The only two nano keyboard shortcuts that you need to know are for WriteOut and Exit. Press the keyboard combination Ctrl+O and after that press Enter to save the file being edited. Press the keyboard combination Ctrl+X to exit nano.
  2. Update your software sources.
    sudo apt-get update
Your edited question shows that your release has changed from Ubuntu 14.04 to Ubuntu 15.04 which is an end of life release. If this is the case, your best option is now a clean install of the latest version of Ubuntu, Ubuntu 16.04. I would also recommend not enabling any Ubuntu 6.10 (edgy) software sources this time.
karel
  • 122,292
  • 133
  • 301
  • 332
its seems your error is a Connection timeout
how ever , if you are using an unsupported version of ubuntu , i advice you
to edit your repo source list and do some minar edits and change your deb mirrors to old-files
  1. sudo cp /etc/apt/source.list /etc/apt/source.bkup
this is a backup , in case something went wrong
  1. sudo gedit /etc/apt/sources.list
find and change archive.ubuntu.com to old-releases.ubuntu.com
  1. sudo apt-get update clean
  2. sudo apt-get update --fix-missing
hopes this help .
