26
I just removed a package from my ubuntu 16.04 system. After removing the package, the terminal shows some warnings like this:
Removing gitlab-ce (8.10.4-ce.0) ...
Purging configuration files for gitlab-ce (8.10.4-ce.0)...
dpkg: warning: while removing gitlab-ce, directory '/opt/gitlab/sv' not empty so not removed
dpkg: warning: while removing gitlab-ce, directory '/opt/gitlab/etc' not empty so not removed
dpkg: warning: while removing gitlab-ce, directory '/opt/gitlab/service' not empty so not removed
dpkg: warning: while removing gitlab-ce, directory '/opt/gitlab/embedded/cookbooks' not empty so not removed
dpkg: warning: while removing gitlab-ce, directory '/opt/gitlab/embedded/ssl/certs' not empty so not removed
dpkg: warning: while removing gitlab-ce, directory '/opt/gitlab/embedded/service/gitlab-rails/public' not empty so not emoved
dpkg: warning: while removing gitlab-ce, directory '/opt/gitlab/embedded/service/gitlab-rails/config/initializers' not empty so not removed
dpkg: warning: while removing gitlab-ce, directory '/opt/gitlab/embedded/service/gitlab-shell' not empty so not removed
dpkg: warning: while removing gitlab-ce, directory '/opt/gitlab/init' not empty so not removed
It says that /opt/gitlab/ directory is not empty, so it cannot remove those from the system.
Should I delete these directory manually or not?
muru
  • 207,228
vivek
  • 363
That directory is populated with gitlab-ce reconfigure command after installation and holds variable data, configurations related to gitlab-ce package.
The recommended process to uninstall it was
  1. Remove services
     sudo gitlab-ctl uninstall
  2. Clean any data generated by usage of the package
     sudo gitlab-ctl cleanse
  3. You may also want to remove any accounts you configured. To do so
     sudo gitlab-ctl remove-accounts
  4. Then remove the package using
     sudo dpkg -P gitlab-ce
Furthermore, gitlab-ce uses these directories (as described here)
  • /opt/gitlab holds application code for GitLab and its dependencies.
  • /var/opt/gitlab holds application data and configuration files that gitlab-ctl reconfigure writes to.
  • /etc/gitlab holds configuration files for omnibus-gitlab. These are the only files that you should ever have to edit manually.
  • /var/log/gitlab contains all log data generated by components of omnibus-gitlab.
So, First remove the package recommended way (Even if you need to reinstall it). You can then remove those data using rm safely.
Information found from omnibus-gitlab README page
Anwar
  • 77,855
11
Filesystem Hierarchy Standard for /opt/:
No other package files may exist outside the /opt, /var/opt, and /etc/opt hierarchies except for those package files that must reside in specific locations within the filesystem tree in order to function properly. For example, device lock files must be placed in /var/lock and devices must be located in /dev.
Anything in /opt/ is maintained by an uninstall-script that basically does a shutdown of the service (if needed) and a bunch of rm's. So if you want to do that manually you need to shutdown the service (if needed) and then rm it.
Mind that /opt/ has a companion /etc/opt/ that might contain files related to that package.
Rinzwind
  • 309,379
