37
I have access to a cluster and wanted to use the simplest example to ssh into it with X11 forwarding and see if it works. Currently, I simply log into the cluster:
$ ssh -Y user@cluster
and the only program that I know in the cluster that has some display (like a gui) is matlab, so I just run it:
$ matlab
in the past that works but I wanted to know of the simplest command to display something in my screen to see if its working or not. Currently, running matlab opens the command interface but it doesn't display an error or anything else.
Does someone know what is an alternative command to see if anything is working? A single command that is inherit with Ubuntu and doesn't require me to install anything beyond X11 is the idea. Something like:
$ display_a_box_with_text HELLOWORLD
I am not sure if its just me but it seems ridiculous that the only way to check if X11 is working is by running MATLAB. There must be a better way to check this.
Instead of the ssh command you issued, try:
$ ssh -v -Y user@cluster
Add another argument -v enable the debugging mode for ssh command. Search for a line containing Requesting X11 forwarding, like in:
debug1: Requesting X11 forwarding with authentication spoofing.
After logging in, you can try the following commands for opening a X window: xterm, xclock, xcalc, xedit, etc These were already mentioned in comments.
You asked for a dialog box with a custom text, so you should try xmessage:
$ xmessage -center hello!
You can try three things
  1. xeyes
  2. xclock
  3. xmessage -center hello!
In case you don't have xmessage, these are alternatives:
  • xdg-open . (sudo apt install xdg-utils)
  • xterm
Those worked on my CentOS 7 server at work.
-2
Here is an answer taken from this post:
To check whether X11 forwarding is enabled, look at the value of the DISPLAY environment variable: echo $DISPLAY. You should see a value like localhost:10 (applications running on the remote machine are told to connect to a display running on the same machine, but that display connection is in fact forwarded by SSH to your client-side display). Note that if DISPLAY isn't set, it's no use setting it manually: the environment variable is always set correctly if the forwarding is in place
Timo
  • 277
