I have Downloaded and installed all the dependencies and .deb packages required to run my software( Custom made GUI software). Now while On the other system I have Installed the same ubuntu version, but it's not connected to Internet. So I have externally downloaded and tried to install .deb packages But I Got errors as below.
dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of libgsl0-dev:i386:
libgsl0-dev:i386 depends on libgsl0ldbl (= 1.15+dfsg-1build1).
dpkg: error processing libgsl0-dev:i386 (--install):
dpkg: dependency problems prevent configuration of libopenscenegraph-dev:i386:
libopenscenegraph-dev:i386 depends on libopenthreads-dev.
libopenscenegraph-dev:i386 depends on libgl1-mesa-dev | libgl-dev.
libopenscenegraph-dev:i386 depends on libglu-dev.
libopenscenegraph-dev:i386 depends on libopenscenegraph80 (= 3.0.1-2).
dpkg: error processing libopenscenegraph-dev:i386 (--install):
dpkg: dependency problems prevent configuration of libosgearth-dev:i386:
libosgearth-dev:i386 depends on libopenscenegraph-dev; however:
Package libopenscenegraph-dev:i386 is not configured yet.
libosgearth-dev:i386 depends on libgeos-dev; however:
Package libgeos-dev:i386 is not configured yet.
Errors are the same for every package, all dependencies probs. I have installed all deb. packages and dependecies in one pc. So My question is , How do copy all same and install on other pc that is not connected to internet. is it possible?
Ax Cool
  • 101
You can solve a dependency issue by installing manually a package with dpkg -i --force-depends <PathToPackageNameThatBlocks.deb>.
Because you said that the second machine does NOT have a internet connection you can try out the tool debmirror on the first machine. The mirror that is created can then be copied to the second machine and included into your /etc/apt/sources.list for apt-get.
The description and manual of this tool can be found by typing man debmirror in the command line.
thedler
  • 314
