I was trying to delete a folder and messed up. I'm getting this error while I'm trying to use sudo:
sudo: error while loading shared libraries: libsudo_util.so.0: cannot open shared object file: No such file or directory
How can I fix this?
How can I fix this?
When sudo not working:
pkexec chmod go-w /usr/lib/sudo/sudoers.so
pkexec chmod 0440 /etc/sudoers
If problem is not solved you can check
The another answer. You can check both the linked , may help to solve your problem.
I think you could open ubuntu software (gui) Search for "synaptic"
Install synaptic package manager .
open synaptic package manager and search for sudo Right click the mouse on sudo choose mark for Reinstallation Then click the big apply button I think sudo will work agin for you Kevin
