On Ubuntu 14.04 LTS (Trusty Tahr), tidy is very old:
$ tidy --version
HTML Tidy for Linux released on 25 March 2009
What's the easiest way to get tidy-html5 installed?
Have I somehow overlooked the package for it?
$ tidy --version
You can install the latest html-tidy from source using the instruction given on its github page.
But the easiest way to install the latest version of html-tidy5 would be downloading the latest binary from this page http://binaries.html-tidy.org/
If you're using 64bit Ubuntu, you'd do basically these commands
wget https://github.com/htacg/tidy-html5/releases/download/5.4.0/tidy-5.4.0-64bit.deb
sudo dpkg -i tidy-5.4.0-64bit.deb
It should be installed fine.
Compile HTML Tidy from sources as described in the Tidy official documentation.
Commands for the compilation of the latest Tidy CLI version for macOS/Linux/Unix:
$ sudo apt-get install xsltproc
$ git clone https://github.com/htacg/tidy-html5.git
$ cd tidy-html5
$ cd build/cmake
$ cmake ../.. -DCMAKE_BUILD_TYPE=Release
$ make
$ sudo make install
This answer is relevant for March 17, 2025. In the future, the data of this answer may be obsolete.
The build on the Travis CI environment.
If you need custom HTML Tidy things, you can need another options. Some citations of HTML Tidy contributor:
If you are just going to use the console app
tidy, which by default is linked with the static librarylibtidys.a, then not building and installing the shared library,libtidy.so, that is-DBUILD_SHARED_LIB:BOOL=OFF, is fine, but this is unusual in unix/linux…There are even some in the unix/linux community that prefer to build the console app tidy linking only with the shared library. See the cmake
-DTIDY_CONSOLE_SHARED:BOOL=ONoption, and see issue #326…And that also means to try to be consistent with the install location, like using
-DCMAKE_INSTALL_PREFIX[:PATH]=/usr, but as stated in most cases the cmake default is also fine… and usually does not represent a problem…
Follow the instructions at the GitHub page. For the prerequisites, I needed to:
sudo apt-get install -y cmake xsltproc
Here's what I did to move from the current apt-get install tidy to the latest version.
Find the URL of the latest version to download at: http://binaries.html-tidy.org.
Try the linux 64-bit DEB first if you're not sure which to pick.
Download it:
wget <LATEST URL>
Remove unneeded tidy-lib package. tidy-lib is included in the .deb you just downloaded.
sudo apt-get -y autoremove tidy
Install the .deb you just downloaded:
sudo dpkg -i tidy-5.2.0-64bit.deb
Clean up:
rm tidy-*.deb
Thanks to @Anwar for pointing me in this direction.
I needed to do hash -d tidy to get bash to run the new version from /usr/local after I installed from source. You also may need to do this if you chose to keep the previous package of tidy.
On the latest Ubuntus (Zesty, 17.04, and Artful, 17.10), it is updated to version 5.2.
There is a backports ppa for Trusty (14.04) and Xenial (16.04): ppa:jonathonf/backports
You could also use the nodejs package html-validator-cli as a workaround
sudo -H npm install -g html-validator-cli
html-validator --filename=path/to/file
but it needs an internet connection.
