I'd like to know or it is possible to set up the GNOME Terminal in a way that when I open up the terminal and there is already an instance open it'll show that instance and not open up a brand new one.
muru
  • 207,228
Mood
  • 802
6 Answers6
I wrote a simple shell script using wmctrl to give the Terminal focus. It does exactly what I want.
First, install wmctrl sudo apt-get install wmctrl.
Next, fire up a text-editor, copy the following lines.
#!/bin/sh
SERVICE='gnome-terminal'
if ps ax | grep -v grep | grep $SERVICE > /dev/null
then
  wmctrl -xa $SERVICE
else
  $SERVICE
fi
Save the file somewhere where you usually keep your shell scripts. In my case I did: ~/bin/single_instance.sh
cd to the directory (cd ~/bin) and make the file executable chmod +x single_instance.sh
Now, open up Main Menu select Accessories » Terminal press properties and replace command with the script: ~/bin/single_instance.sh
Open up System Settings » Keyboard » Shortcuts. Disable Launch Terminal shortcut by giving it a backspace. Make a custom shortcut. Again fill in the path and name to the script and give it the key combination ctrl + alt + t.
You’re done, single instance terminal...
Mood
  • 802
Add --tab to the launcher command. Then you end up with only one app. open.
~$ gnome-terminal --help-all
--tab       Open a new tab in the last-opened window with the default profile
david6
  • 14,528
  • 38
  • 46
Method 1 - Remap gnome dock shortcut
  1. Add gnome-terminal into dock (favortie), I move it to the third application, please change the number 3 in following article to the number you used.
  2. Disable terminal shortcut in Settings/Kebyaord/Keyboard Shortcuts
  3. Reset the shortcut to for start dock applications gsettings set org.gnome.shell.keybindings switch-to-application-3 "['<Ctrl><Alt>T']"
Method 2 (Xorg only) - Reset gnome default terminal
  1. Create a script at ~/bin/single_gnome_terminal.sh
#!/bin/sh
if ps ax | grep -v grep | grep $SERVICE > /dev/null then wmctrl -xa $SERVICE else $SERVICE fi
  1. Enable execution permission
chmod +x ~/bin/single_gnome_terminal.sh`
  1. Install wmctrl
  1. Change default terminal
gsettings set org.gnome.desktop.default-applications.terminal exec single_gnome_terminal.sh
References:
  1. https://askubuntu.com/a/1194659
  2. https://askubuntu.com/a/87109
  3. https://unix.stackexchange.com/a/510376
I'd like to add my own script, since I find it extremely useful:
  1. If there is a gnome-terminal in the current workspace, then it brings it to the front and gives it focus
  2. If there isn't any gnome-terminal in the current workspace, it switches the workspace and brings the first existing gnome-terminal it finds to front and gives it focus
  3. If there are no gnome-terminal instances running, it opens a new instance, brings it to front and gives it focus
I configured Ctrl+Alt+T shortcut to run this script and I find it even more comfortable than Guake or Tilda.
#!/usr/bin/env sh
# APP is the binary name you see when you do ps
APP="gnome-terminal"
# WIN_CLASS is the window class you see when you do wmctrl -lx
WIN_CLASS="gnome-terminal-server.Gnome-terminal"
# Use the app from current workpace first, or any if not available
WORKSPACE=$(wmctrl -d | grep '\*' | cut -d ' ' -f1)
TPID=$(ps aux | pgrep $APP)
if [ "$TPID" ]
then
  QTERM_WIN=$(wmctrl -lx | grep $WIN_CLASS | grep $WORKSPACE  | awk 'NR == 1 {print $1}')
  if [ "$QTERM_WIN" ]
  then
    wmctrl -ia $QTERM_WIN
  else
    # No valid app found in the current workspace, switch to any
    QTERM_WIN=$(wmctrl -lx | grep $WIN_CLASS | awk 'NR == 1 {print $1}')
  fi
else
  $APP &
fi
I use it with QTerminal but I modified to fit your needs. Good luck
Emilio
  • 361
I generalized and simplfied @Mood 's script a bit. Now it takes a command line parameter and use pgrep instead.
sudo apt-get install procps
The script:
#!/usr/bin/env bash
if pgrep $1
then
    wmctrl -xa $1
else
    $1
fi
muru
  • 207,228
Einar
  • 131
It is the default behavior if you use Mod4+# (Mod4 = Super = "Windows" key, # is number in launcher) shortcut to open any application.
int_ua
  • 8,892
