I am working on a networking project that requires me to have eth0 interface. On doing an ifconfig this is what I see.
anuvrattiku@anuvrattiku-Inspiron-13-7368:~$ ifconfig
lo        Link encap:Local Loopback
      inet addr:127.0.0.1  Mask:255.0.0.0
      inet6 addr: ::1/128 Scope:Host
      UP LOOPBACK RUNNING  MTU:65536  Metric:1
      RX packets:14335 errors:0 dropped:0 overruns:0 frame:0
      TX packets:14335 errors:0 dropped:0 overruns:0 carrier:0
      collisions:0 txqueuelen:1
      RX bytes:1743272 (1.7 MB)  TX bytes:1743272 (1.7 MB)
wlp1s0    Link encap:Ethernet  HWaddr 68:07:15:23:f2:f8
      inet addr:192.168.0.16  Bcast:192.168.0.255  Mask:255.255.255.0
      inet6 addr: fe80::5fff:b2a0:e985:b475/64 Scope:Link
      inet6 addr: 2601:646:8501:c10:f91:29b7:c0fd:3ebb/64 Scope:Global
      UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
      RX packets:315519 errors:0 dropped:0 overruns:0 frame:0
      TX packets:64909 errors:0 dropped:0 overruns:0 carrier:0
      collisions:0 txqueuelen:1000
      RX bytes:391223230 (391.2 MB)  TX bytes:9020230 (9.0 MB)
Is there any way to get eth0 up. I tried adding eth0 to the /etc/network/interfaces file but it is not working.
Here is the error.
[BroControl] > start
starting bro (was crashed) ...
bro terminated immediately after starting; check output with "diag"
[BroControl] > diag
[bro]
Bro 2.4.1
Linux 4.4.0-36-generic
==== No reporter.log
==== stderr.log
fatal error: problem with interface eth0 (eth0: SIOCETHTOOL(ETHTOOL_GET_TS_INFO) ioctl failed: No such device)
==== stdout.log
max memory size         (kbytes, -m) unlimited
data seg size           (kbytes, -d) unlimited
virtual memory          (kbytes, -v) unlimited
core file size          (blocks, -c) unlimited
==== .cmdline
-i eth0 -U .status -p broctl -p broctl-live -p standalone -p local -p bro local.bro broctl broctl/standalone broctl/auto
Is there any workaround here.
The error you're getting is happening because you don't have an eth0 interface. You do have a wlp1s0 interface. You'll have to edit the program to use the device you have (or install a new hardware device).
Looking at the github site there is a sample node.cfg file where this is configured.
Change the line in the node.cfg file:
Change from:
[bro]
type=standalone
host=localhost
interface=eth0
Change to:
[bro]
type=standalone
host=localhost
interface=wlp1s0
L. D. James
  • 25,444
