Can my old laptop with a Intel Atom N450 1.66 GHz run ubuntu without that much lag? It only has 1gb of ram which i feel might be an issue
Asked
Active
Viewed 1.3k times
-1
The real issue will be whether or not you are able to install AT ALL. If your laptop does not read DVDs and cannot boot from a flashdrive (which I suspect), then you’re stuck. If you can boot from a live DVD or flashdrive, then you’re in luck. The Ubuntu installer will allow you to try it out without installing. Run this option and goof around with it for a while. If it lags too much then you are best going with a lighter weight Linux version.
bashBedlam
- 1,072
- 1
- 8
- 16
