Just tried to do sudo apt-get dist-upgrade today; and I came to this state:
$ sudo apt-get upgrade
Reading package lists... Done
Building dependency tree
Calculating upgrade... Done
The following packages have been kept back:
phablet-tools ubuntu-sdk
0 upgraded, 0 newly installed, 0 to remove and 2 not upgraded.
Ok, ubuntu-sdk has been kept back/held back, probably there are new packages to install due to dependencies; so I try dist-upgrade:
$ sudo apt-get dist-upgrade
The following NEW packages will be installed:
intltool
ubuntu-sdk
0 upgraded, 1 newly installed, 0 to remove and 1 not upgraded.
Need to get 52.0 kB of archives.
After this operation, 245 kB of additional disk space will be used.
Do you want to continue? [Y/n] y
Get:1 http://dk.archive.ubuntu.com/ubuntu/ trusty/main intltool all 0.50.2-2 [52.0 kB]
Fetched 52.0 kB in 0s (872 kB/s)
Selecting previously unselected package intltool.
(Reading database ... 343935 files and directories currently installed.)
Preparing to unpack .../intltool_0.50.2-2_all.deb ...
Unpacking intltool (0.50.2-2) ...
Processing triggers for man-db (2.6.7.1-1ubuntu1) ...
Setting up intltool (0.50.2-2) ...
Hmm... so just intltool installed there, not ubuntu-sdk; let's try again:
Hmmm... dist-upgrade again?
ubuntu-sdk
0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
Still kept back... Let's try force a bit more with sudo apt-get install...:
$ sudo apt-get install phablet-tools ubuntu-sdk
ubuntu-sdk : Depends: ubuntu-device-flash but it is not going to be installed
Let's try then ubuntu-device-flash:
$ sudo apt-get install ubuntu-device-flash
ubuntu-device-flash : Depends: click-ubuntu-policy but it is not installable
Depends: ubuntu-snappy-cli but it is not installable
Let's just try click-ubuntu-policy, although by now I don't have high hopes:
$ sudo apt-get install click-ubuntu-policy
Package click-ubuntu-policy is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package 'click-ubuntu-policy' has no installation candidate
Great, so apparently click-ubuntu-policy it is not in repos anymore, but it still has a dangling dependency in ubuntu-device-flash package.
What is the recommended course of action I could do in this case?
