TL;DR: How do I get rid of the warnings in the subject line when everything else looks sweet?
I'm getting the following output when running testdisk's Analyze on a 64GB SD card:
TestDisk 6.14, Data Recovery Utility, July 2013
Christophe GRENIER <grenier@cgsecurity.org>
http://www.cgsecurity.org
Disk /dev/sdb - 63 GB / 59 GiB - CHS 60906 64 32
Current partition structure:
     Partition                  Start        End    Size in sectors
Warning: number of heads/cylinder mismatches 255 (FAT) != 64 (HD)
Warning: number of sectors per track mismatches 63 (FAT) != 32 (HD)
 1 P FAT32 LBA                0   1 32 51199  63 32  104857537 [27GB]
 2 P Linux                51200   0  1 60902  63 32   19871744 [Link2SD]
No partition is bootable
Both partitions are fsck-clean, and /dev/sdb1 is also chkdsk-clean under Win10.
fsck -l says: (it all looks good to me)
Disk /dev/sdb: 63.9 GB, 63864569856 bytes
64 heads, 32 sectors/track, 60906 cylinders, total 124735488 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk identifier: 0x1c580740
   Device Boot      Start         End      Blocks   Id  System
/dev/sdb1              63   104857599    52428768+   c  W95 FAT32 (LBA)
/dev/sdb2       104857600   124729343     9935872   83  Linux
If I try to set the geometry mentioned in testdisk's mismatch warning (H=255, S=63) I get:
Disk /dev/sdb - 63 GB / 59 GiB - CHS 7765 255 63
 1 P FAT32 LBA                0   1  1  6527  21 22  104857537 [27GB]
Bad relative sector.
 2 P Linux                 6527  21 23  7764  10 54   19871744 [Link2SD]
Note that the sector 6527 is now "shared" which doesn't seem right.
How can I remove the initial mismatch warnings?
