I am trying to set meshlab as the default application to open .obj files.
I attempted (as mentioned in here) right click a random obj file -> properties -> Open With -> there is no meshlab to choose from and there is no way I can add meshlab into it.
The weird thing is when I do the same step for .ply file, there actually is an option to choose meshlab to set as the default application.
Now I need to open meshlab first, and drag the obj file in it, which is a lot more hassle than just double clicking the obj file to open it.
What should I do so I can open .obj files with meshlab by default?
user3667089
  • 510
  • 14
First, run mimetype on your file to get the mimetype as follows:
$ mimetype bunny.obj
bunny.obj: application/x-tgif
Once you've determined the corresponding mimetype, add your application as the default in /usr/share/applications/defaults.list:
$ sudo su
$ echo "application/x-tgif=meshlab.desktop" >> /usr/share/applications/defaults.list
It's important to use two > symbols in the command above, not one. Consider making a backup of /usr/share/applications/defaults.list beforehand as well.
