I am running ubuntu 16.04 and I have installed android-sdk using :-
sudo apt-get install android-sdk
and after installation , when i run
android
it says command not found.
I cannot even see "android-sdk" in my home folder.
When i run sudo apt-get install android-sdk command again , it says
android-sdk is already the newest version (24.3.3+2).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
I even tried finding "android" in my "/home/username" directory , "root" directory.
I cannot find it.
  • Uninstall actual android-sdk:
    sudo apt-get purge android-sdk
  • Download the latest android-sdk using:
    wget http://dl.google.com/android/android-sdk_r24.2-linux.tgz
  • Unpack downloaded package to your HOME directory:
    tar -xvf android-sdk_r24.2-linux.tgz
  • Set ANDROID_HOME path
Now you should able to use android command.
Try to update your sdk using:
android update sdk --no-ui
Hope it will help
