Is there anyone that is familiar with the i915 video driver issues with 16.04? For me, it manifests as the external monitors going blank intermittently and then combing back on after a few seconds. I've attempted the fix at https://aboutsimon.com/blog/2016/07/...ntel-i915.html which did not correct the issue.
I have attempted to install kernel 4.6, but it only resulted in a blank screen immediately after the login screen was displayed upon boot-up.
The output of lshw -c video is as follows:
*-display
description: VGA compatible controller
product: Broadwell-U Integrated Graphics
vendor: Intel Corporation
physical id: 2
bus info: pci@0000:00:02.0
version: 09
width: 64 bits
clock: 33MHz
capabilities: msi pm vga_controller bus_master cap_list rom
configuration: driver=i915 latency=0
resources: irq:48 memory:f6000000-f6ffffff memory:e0000000-efffffff ioport:f000(size=64)
Current kernel information is as follows:
simpsonc@simpsonc-nbk:~$ uname -r
4.4.0-36-generic
simpsonc@simpsonc-nbk:~$ uname -v
#55-Ubuntu SMP Thu Aug 11 18:01:55 UTC 2016
When an external monitor goes blank, the following errors are sometimes written to syslog:
Sep 4 16:49:00 simpsonc-nbk kernel: [ 9709.832348] [drm:intel_cpu_fifo_underrun_irq_handler [i915]] *ERROR* CPU pipe B FIFO underrun
Sep 4 17:13:48 simpsonc-nbk kernel: [11197.640834] [drm:intel_cpu_fifo_underrun_irq_handler [i915]] *ERROR* CPU pipe C FIFO underrun
It may also be worth noting that this seems to coincide with keystrokes, but this may be merely a coincidence. Any assistance or advice would be greatly appreciated as this has become quite annoying. Please let me know if any further information would be helpful.
