When I have updated my computer to Ubuntu 16.04, xpra package has updated to v0.15.8.
I have some compatibility problems with this version. I have read that v0.15.x is an unsupported version and v0.14.x is the current LTS (long term support) release (https://www.xpra.org/trac/wiki/Versions).
How can I install xpra V0.14.x on ubuntu 16.04?
Updating to 0.14.x still did not allow me to launch xpra but updating to the latest branch 2.0.x did.
TL;DR copied from my blog:
# Administrator privileges
sudo su -
# Import the packager's key:
apt-get install curl
curl http://winswitch.org/gpg.asc | apt-key add -
# Xenial Xerus (16.04)
echo "deb http://winswitch.org/ xenial main" > /etc/apt/sources.list.d/winswitch.list;
apt-get install software-properties-common >& /dev/null;
add-apt-repository universe >& /dev/null;
apt-get update;
apt-get install winswitch
MadMike
  • 4,275
  • 29
  • 50
brtknr
  • 71
Open the terminal and type:
cd Desktop/
wget -c http://xpra.org/dists/xenial/main/binary-amd64/xpra_0.14.35-1_amd64.deb # official deb package from xpra.org
sudo dpkg -i xpra_0.14.35-1_amd64.deb
xpra v0.14.x is the current LTS (long term support) release, and xpra_0.14.35-1_amd64.deb is compatible with Ubuntu 16.04.
If you get a broken packages message when updating software, then remove xpra using this command:
sudo dpkg -r xpra
If you still get a broken packages message when updating software, then it wasn't xpra's fault. You need to solve the broken packages error message first before you install xpra. This should be asked as a separate question however.
karel
  • 122,292
  • 133
  • 301
  • 332
