I have downloaded a program to the downloads folder, it is as pasted......
/home/rod/Downloads/eagle-lin32-7_6_0-1.run
The question is : How do I get it to install or run?? The program is for Linux 32 bit but I cannot find any way to get it to go. Regards, Rod. J.
L. D. James
  • 25,444
This one line command should do the trick
chmod +x /home/rod/Downloads/eagle-lin32-7_6_0-1.run && ./home/rod/Downloads/eagle-lin32-7_6_0-1.run
Since run is an executable you have to use the terminal to run
./(executable-file-with-extension)
dunstorm
  • 101
