i have a lot's of tar.gz files in random place and i want to look for a file inside all of tar.gz file
for example :
/root/a.tar.gz
/home/backup-2016.tar.gz
/home2/user/files/2015/abc.tar.gz
i am looking for file or folder inside of them
You can use this (rather long) one-liner, replacing PATTERN with your search pattern (case insensitive unless you remove the -i option after grep):
find / -iname "*.tar.gz" -exec bash -c 'result=$(set -o pipefail ; echo "{}" ; tar -tf {} | grep -i "PATTERN" | sed "s/^/    /") ; test $? -eq 0 && printf "$result\n"' \;
If you don't want to search your whole computer but just a specific directory (recursively), you may specify that as first argument after find instead of the /. The .tar.gz suffix for archives to process is case insensitive as well unless you replace the -iname after find with name.
The output might look somehow like this (searching in /usr/share/doc for the pattern default):
/usr/share/doc/openjdk-8-jre-headless/test-amd64/failed_tests-hotspot.tar.gz
    test/langtools/JTwork/tools/javac/lambda/methodReferenceExecution/MethodReferenceTestInnerDefault.jtr
    test/langtools/JTwork/tools/javac/lambda/methodReferenceExecution/MethodReferenceTestSuperDefault.jtr
    test/langtools/JTwork/tools/javac/lambda/methodReferenceExecution/MethodReferenceTestVarArgsSuperDefault.jtr
    test/langtools/JTwork/tools/javac/lambdaShapes/org/openjdk/tests/vm/DefaultMethodsTest.jtr
/usr/share/doc/apg/php.tar.gz
    ./themes/default.php
You see the archive path in one line followed by all content entries matching the pattern, each in a separate line indented by 4 spaces.
This can be also put in a script (e.g. archive-search, don't forget to make it executable with chmod +x FILENAME):
#!/bin/bash
# Usage:   archive-search PATTERN DIRECTORY
find "$2" -iname "*.tar.gz" -exec bash -c '
        result=$(
                set -o pipefail
                echo "{}"
                tar -tf {} | grep -i "$0" | sed "s/^/    /"
' "$1" \;
or in a Bash function (e.g. archive-search, append to your ~/.bashrc if you want to have it available in every new Bash session):
archive-search () {
            result=$(
                    set -o pipefail
                    echo "{}"
    ' "$1" \;
Both the script and the function take search pattern and directory as command-line arguments, like this:
archive-search "default" /usr/share/doc
Byte Commander
  • 110,243
With zfind you can do:
zfind 'name like "file%" and archive'
to search for a file named file* inside any archive (tar/zip/7z/rar).
laktak
  • 557
