I get choppy sound output over hdmi with the command.
aplay /usr/share/sounds/alsa/Front_Center.wav
My current configuration can can be found here: alsa-info.sh output
Sound worked after some tweaking with 10.04. After upgrade to 11.10 sound stopped working properly. A fresh installation of 11.10 did not change the situation.
Video over hdmi works without problems. As soon as I run speaker-test I get fluent sound again. Workaround to trigger speaker-test after login is obvious but I would like a real fix to that problem.
How can I fix this?
coversnail
  • 6,406
Bjoern
  • 61
This problem was solved by the OP:
The following configuration fixed the problem:
1) Added the following line to /etc/pulse/default.pa
load-module module-alsa-siice=hw:0,8
2) Added the following line to /etc/modprobe.d/alsa-base.conf
options snd-hda-intel model=mbp55 enable=1 index=0 position_fix=1
The last three parameters actually solved the problem. Before that I had to run speaker-test to get fluent sound. dmesg returned the following error but afterwards sound was okay.
hda-intel: Invalid position buffer, using LPIB read method instead.
3) I am not sure if this is related but I had temporarily success with the following grub boot parameter in /etc/default/grub
GRUB_CMDLINE_LINUX="nomodeset noacpi"
I am still not sure what the problem was. If anyone could tell me I would like to learn it. Thanks.
Some useful resources:
ftp://download.nvidia.com/XFree86/gpu-hdmi-audio-document/gpu-hdmi-audio.html http://my.opera.com/Hoelli/blog/show.dml/1646577
coversnail
  • 6,406
