I have upgraded to Ubuntu 16.04 and I have installed dnscrypt-proxy from repository. Then I have just edited the /etc/default/dnscrypt-proxy file changing the DNSCRYPT_PROXY_RESOLVER_NAME="" line with DNSCRYPT_PROXY_RESOLVER_NAME=cisco. After that I have just ran the following commands:
sudo service dnscrypt-proxy stop
sudo service dnscrypt-proxy start
and everything was working fine.
The problem is that after reboot my internet connection does not work and I have to run this again:
to make it work. What I need is a way to make dnscrypt-proxy starts automatically at startup like it used to work before upgrading to 16.04.
I tried to put those commands in /etc/rc.local file but sometimes it did not work. Also I created a bash script with those commands and I made it run at startup, but still no luck.
Could you help me?
Thanks
Frank
  • 1,583
The following things helped me:
  • run sudo systemctl edit --full dnscrypt-proxy.service
  • replace
    After=network.target iptables.service firewalld.service
    to
    Before=nss-lookup.target
  • run sudo systemctl edit --full dnscrypt-proxy.socket
  • delete After=network.target
Also /etc/systemd/system/dnscrypt-proxy.service and /etc/systemd/system/dnscrypt-proxy.socket can be replaced with their latest versions.
