I ran across this problem while I tried to answer a question on Stackoverflow.
On shutdown, Ubuntu 12.04 sends SIGTERM to all processes and waits at most 10 seconds before killing them with SIGKILL (unless they terminated before). My answer on SO even contains a Python script that verifies that behaviour. The script is started in a terminal, sent to the background and than disowned by the terminal. When receiving SIGTERM, the script just keeps going and continuously prints to a file how long it has been running after receiving SIGTERM.
Ubuntu 16.04 however, the script is killed immediately on shutdown (no SIGTERM is logged).
I googled for a while, but I could not find anything useful. Has nobody ever come across that breaking change for the current LTS release?
Here is the script signaltest.py
import signal
import time
stopped = False
out = open('log.txt', 'w')
def stop(sig, frame):
global stopped
stopped = True
out.write('caught SIGTERM\n')
out.flush()
signal.signal(signal.SIGTERM, stop)
while not stopped:
out.write('running\n')
out.flush()
time.sleep(1)
stop_time = time.time()
while True:
out.write('%.4fs after stop\n' % (time.time() - stop_time))
out.flush()
time.sleep(0.1)
The script uses the file log.txt in the current directory for all output. It has a loop that prints 'running' every second. Receiving SIGTERM breaks the loop ans starts another loop which prints the seconds elapsed since receiving SIGTERM.
The script is run from a terminal a detached using disown:
python signaltest.py &
disown
Just to be clear: This is not a duplicate of Ubuntu is not sending SIGTERM on shutdown. The question is about desktop applications and the answers do not fit either.
