How do I update Node 6.4.0 to 6.5.0 on Ubuntu 16.04 via apt package manager?
It's better to use nvm (node version manager) due to its flexibility and it allows you to easily switch versions.
It's simple to install; run:
curl -o- https://raw.githubusercontent.com/creationix/nvm/v0.33.11/install.sh | bash
then:
export NVM_DIR="$HOME/.nvm"
[ -s "$NVM_DIR/nvm.sh" ] && \. "$NVM_DIR/nvm.sh" # This loads nvm
once it's installed (restart session if necessary), install and switch version by running these simple commands:
nvm install 9 # will install version 9 of node
nvm use 9 # will switch to version 9
nvm alias default 9 # will use version by default upon boot
- 509
You might consider adding the node sources ppa to your set up. There are instructions here.
You could also try nave which is a non-apt way managing the versions of node on your system. Running sudo nave usemain 6.5.0 will install 6.5.0 to your system folders though I'd recommend using the nave.sh sub-shell approach to access different versions of node without doing central installs.
- 116
