14
It may be a newbie's question, but I don't understand how this is configured and why the output format of time command is different in these two cases:
if used via time, the output is three rows with basic info
$ time sleep 1
real    0m1.003s
user    0m0.000s
sys     0m0.000s
then I can check out which binary is used
$ which time
/usr/bin/time
and call it directly to get output in a completely different format, with much more info
$ /usr/bin/time sleep 1
0.00user 0.00system 0:01.00elapsed 0%CPU (0avgtext+0avgdata 2000maxresident)k
0inputs+0outputs (0major+77minor)pagefaults 0swaps
there are no aliases related to time
$ alias | grep time
I'm running Ubuntu 16.04.
muru
  • 207,228
xaxa
  • 439
  • 15
The first one is the bash's own builtin keyword time (compiled with bash), and the second one is the external executable time (/usr/bin/time, comes with the time package).
Also, which can't show the shell's builtin commands or keywords as it just searches through PATH, you need to use type for that. Being a shell builtin itself, type can additionally check for shell's internal entities (and also PATH), so you can spot the difference by:
type -a time
Here:
$ type -a time
time is a shell keyword
time is /usr/bin/time
The first one will be executed if you just use time. You can also get which is being executed by just using type (without -a):
type time
The -a tells type to search in shell's internal entities and also in PATH i.e. search in all possible sources.
If for some reason you need the external one, use any one of:
\time
"time"
'time'
command time
heemayl
  • 93,925
Another difference between the builtin and external utilities is, that Bash's builtin time will time complete pipelines or calls to shell functions (apparently even loops, but the manual doesn't seem to promise that). The external time cannot, since being outside the shell, doesn't know about the surrounding code.
bash$ time echo blah | sleep 3
real    0m3.002s
bash$ /usr/bin/time echo blah | sleep 3
0.00user 0.00system 0:00.00elapsed ?%CPU
bash$ time for x in 1 2 3 ; do sleep 1 ; done
real    0m3.006s
While time is specified in the standard, it's left unspecified how it should act in a pipeline, so a more powerful internal implementation like this is possible.
ilkkachu
  • 1,887
