Linux provides a nice interface for monitoring all file system events like creating, modifying, removing files. The interface is inotify family of system calls, the userspace utilities leveraging these calls are provided by the inotify-tools package in Ubuntu (available on the universe repository). If you don't have it already, install by:
sudo apt-get install inotify-tools
inotify-tools provides inotifywait and inotifywatch binaries, we need the first one.
So you want to run the command asciidoctor -q some_file when any .adoc file is modified (some_file will replaced by that), if so assuming your .adoc files are in directory /foo/bar, you can set the watch:
inotifywait -qm --event modify --format '%w' /foo/bar/*.adoc
- -qenables the quiet mode,  no info from- inotifywaititself
- -menables monitor mode, otherwise it will exit after the first event
- --event modify, we are only interested in- modifyevent i.e. when a file is modified. Other possible values include- open,- closeetc.
- --format %w, we only want the file name that is modified rather than bunch of other info as we will use the file name as input to another command
- /foo/bar/*.adocwill be expanded to all- .adocfiles under- /foo/bardirectory
Now the above will show you the filename whenever any is modified, now to run the command on the filename (assuming the command takes arguments via STDIN):
inotifywait -qm --event modify --format '%w' /foo/bar/*.adoc | while read -r file ; do
    asciidoctor -q "$file"
done
You can also setup a recursive watch on the directory, you will then need to use grep to filter the desired files only. Here setting the watch recursively (-r) on directory /foo/bar and using grep to filter only .adoc files:
inotifywait -qrm --event modify --format '%w%f' /foo/bar | grep '\.adoc$' | while read -r file ; do
done
When watching directories the output format specifier %w resolves to the directory name, so we need %f to get the file name. While watching files, %f would resolve to empty string.
Note that, you can also run inotifywait in daemon (-d) mode, you can also script the whole  thing, and/or run in background, and/or play with it more other options.
Also, you can replace asciidoctor with any other command of your choice, if you want.
Check man inotifywait to get more idea.
