I've seen a lot of posts about streaming audio to their AppleTV / other airplay audio devices... but I want to share my screen.
Is there a way I can do this?
I'm on Ubuntu 16.04.
Connect to the wifi network of the AppleTV
Download or clone from this link: https://github.com/jamesdlow/open-airplay
Once you have downloaded the .zip, unzip it and enter the folder open-airplay-master.
The document “Dockerfile” contains the list of instructions: From terminal:
sudo apt-get update
sudo apt-get install -y default-jdk
sudo apt-get install -y maven2
Apparently the maven2 library is not available on Ubuntu 16. In this case, you should install the maven library with the same command as above.
From terminal:
cd open-airplay-master/Java
ant
The command ant builds the airplay.jar file in the open-airplay-master/Java/build folder.
From terminal:
java -cp "build/airplay.jar:lib/jmdns.jar" com.jameslow.AirPlay
You should see a searching window for few seconds. It should find the AppleTV automatically (click OK). Select resolution and click OK.
Now you should see your screen projected.
No. Airplay is a proprietary protocol that hasn't been fully reverse engineered. That might even never happen.
If you are not bound to Apple, you might look into DLNA.
Well, there is a way - https://github.com/jamesdlow/open-airplay It is not really fancy, but it works:
It should show list of available devices after a few seconds, then ask for resolution and finally share your screen.
