When trying to follow step 3 of this answer, I get an error when launching ./android command from the folder android-sdk-linux/tools folder:
perissf@perissf-ubuntu:~/Scaricati/android-sdk-linux/tools$ ./android
<p>(Android SDK Manager:6135): GLib-GObject-CRITICAL **: g_type_add_interface_static: assertion 'g_type_parent (interface_type) == G_TYPE_INTERFACE' failed</p> <p>(Android SDK Manager:6135): GLib-GObject-CRITICAL **: g_type_add_interface_static: assertion 'g_type_parent (interface_type) == G_TYPE_INTERFACE' failed</p>
However, despite the error, the Android SDK Manager window opens anyway.
In the system there are the preinstalled Java and OpenJDK, but I have installed the Oracle JRE and set it as default:
perissf@perissf-ubuntu:~$ java -version
<p>java version "1.8.0_101"</p> <p>Java(TM) SE Runtime Environment (build 1.8.0_101-b13)</p> <p>Java HotSpot(TM) 64-Bit Server VM (build 25.101-b13, mixed mode)</p> <p>perissf@perissf-ubuntu:~$ javac -version</p> <p>Il programma "javac" può essere trovato nei seguenti pacchetti:</p> <ul> <li><p>default-jdk</p></li> <li><p>ecj</p></li> <li><p>gcj-5-jdk</p></li> <li><p>openjdk-8-jdk-headless</p></li> <li><p>gcj-4.8-jdk</p></li> <li><p>gcj-4.9-jdk</p></li> <li><p>openjdk-9-jdk-headless</p></li> </ul> <p>Provare: sudo apt install <code><PACCHETTO SELEZIONATO></code></p>
And my question is: should I care about this error or go on anyway?
