13
A very basic question.
Whether all packages installed by apt-get install reside in the same folder? If yes, where?
If no, how to find the location?
I am in the case of installing matplotlib Basemap and it requires me to know where libgeos_c or geos_c.h file are located. I installed libgeos-3.4.2 using apt-get install and had no idea to find those files. Further question, what is whichcommand doing? I did which libgeos and it didn't output, while doing which python gave /usr/bin/python
iparjono
  • 243
The basic answer is no, different applications install in different locations, and consist of multiple files. As a general rule the actual application will be installed in one of the locations in your PATH env variable, and you can check the directories in that variable with:
echo $PATH
But if you're trying to find a specific package's location you can use the dpkg command with the -L flag. For example if you wanted to find all of the installed files for Apache2, you could run:
dpkg -L apache2
Darian
  • 306
