I'm having weird issues after an upgrade from 14.04.5 to 16.04.1.
Here is what I get from sudo apt-get update:
Hit http://archive.ubuntu.com xenial InRelease
Get:1 http://archive.ubuntu.com xenial-updates InRelease [95.7 kB]
Get:2 http://archive.ubuntu.com xenial-security InRelease [94.5 kB]
Get:3 http://repo.percona.com xenial InRelease [15.3 kB]
Hit http://archive.ubuntu.com xenial/main amd64 Packages
Hit http://archive.ubuntu.com xenial/universe amd64 Packages
Hit http://archive.ubuntu.com xenial/main Translation-en
Hit http://archive.ubuntu.com xenial/universe Translation-en
Get:4 http://archive.ubuntu.com xenial-updates/main amd64 Packages [383 kB]
Get:5 http://archive.ubuntu.com xenial-updates/universe amd64 Packages [324 kB]
Get:6 http://archive.ubuntu.com xenial-updates/main Translation-en [145 kB]
Get:7 http://archive.ubuntu.com xenial-updates/universe Translation-en [111 kB]
Get:8 http://archive.ubuntu.com xenial-security/main amd64 Packages [138 kB]
Hit http://repo.percona.com xenial/main Sources
Get:9 http://archive.ubuntu.com xenial-security/universe amd64 Packages [41.5 kB]
Get:10 http://archive.ubuntu.com xenial-security/main Translation-en [57.0 kB]
Get:11 http://archive.ubuntu.com xenial-security/universe Translation-en [25.1 kB]
Get:12 http://repo.percona.com xenial/main amd64 Packages [16.9 kB]
Hit https://apt.dockerproject.org ubuntu-xenial InRelease
Hit https://apt.dockerproject.org ubuntu-xenial/main amd64 Packages
Get:13 https://download.serverpilot.io xenial InRelease
Ign http://repo.percona.com xenial/main Translation-en_US
Get:14 https://apt.dockerproject.org ubuntu-xenial/main Translation-en_US
Get:15 https://download.serverpilot.io xenial/main amd64 Packages
Get:16 https://download.serverpilot.io xenial/main Translation-en_US
Ign https://apt.dockerproject.org ubuntu-xenial/main Translation-en_US
Hit https://packages.gitlab.com xenial InRelease
Ign https://download.serverpilot.io xenial/main Translation-en_US
Hit https://packages.gitlab.com xenial/main Sources
Hit https://packages.gitlab.com xenial/main amd64 Packages
Get:17 https://packages.gitlab.com xenial/main Translation-en_US
Ign https://packages.gitlab.com xenial/main Translation-en_US
Fetched 1,453 kB in 4s (341 kB/s)
Reading package lists... Done
W: Unknown Multi-Arch type 'no' for package 'compiz-core'
W: Unknown Multi-Arch type 'no' for package 'compiz-gnome'
W: Unknown Multi-Arch type 'no' for package 'libxapian-dev'
W: Ignoring Provides line with DepCompareOp for package python-cffi-backend-api-max
W: Ignoring Provides line with DepCompareOp for package python-cffi-backend-api-min
W: Ignoring Provides line with DepCompareOp for package python3-cffi-backend-api-max
W: Ignoring Provides line with DepCompareOp for package python3-cffi-backend-api-min
W: Unknown Multi-Arch type 'no' for package 'kwin'
W: Unknown Multi-Arch type 'no' for package 'kwin-dev'
W: Unknown Multi-Arch type 'no' for package 'kwin-wayland'
W: Unknown Multi-Arch type 'no' for package 'kwin-x11'
W: Unknown Multi-Arch type 'no' for package 'libkf5sysguard-dev'
W: Ignoring Provides line with DepCompareOp for package php-psr-http-message-implementation
W: Ignoring Provides line with DepCompareOp for package php-psr-log-implementation
W: Ignoring Provides line with DepCompareOp for package php-seclib
W: Ignoring Provides line with DepCompareOp for package php-sabre-http
W: Ignoring Provides line with DepCompareOp for package php-math-biginteger
W: Ignoring Provides line with DepCompareOp for package pypy-cffi
W: Ignoring Provides line with DepCompareOp for package pypy-cffi-backend-api-max
W: Ignoring Provides line with DepCompareOp for package pypy-cffi-backend-api-min
W: You may want to run apt-get update to correct these problems
Here is what I get from sudo apt-get autoremove:
Building dependency tree
You might want to run 'apt-get -f install' to correct these.
 libc-dev-bin : Depends: libc6 (< 2.20) but 2.23-0ubuntu3 is installed
                Recommends: manpages-dev but it is not installed
 libc6-dev : Depends: libc6 (= 2.19-0ubuntu6.9) but 2.23-0ubuntu3 is installed
E: Unmet dependencies. Try using -f.
Here is what I get from sudo apt-get -f install
Correcting dependencies... Done
The following packages were automatically installed and are no longer required:
  libarchive-extract-perl liblog-message-simple-perl libmodule-pluggable-perl
  libmysqlclient18 libpam-systemd libpod-latex-perl libsystemd-login0
  libterm-ui-perl libtext-soundex-perl
Use 'apt-get autoremove' to remove them.
The following extra packages will be installed:
  libc-dev-bin libc6-dev manpages
Suggested packages:
  glibc-doc
Recommended packages:
  manpages-dev
The following NEW packages will be installed:
  manpages
The following packages will be upgraded:
2 upgraded, 1 newly installed, 0 to remove and 392 not upgraded.
8 not fully installed or removed.
Need to get 0 B/3,240 kB of archives.
After this operation, 2,457 kB of additional disk space will be used.
Do you want to continue? [Y/n] y
Unescaped left brace in regex is deprecated, passed through in regex; marked by <-- HERE in m/^(.*?)(\\)?\${ <-- HERE ([^{}]+)}(.*)$/ at /usr/share/perl5/Debconf/Question.pm line 72.
Unescaped left brace in regex is deprecated, passed through in regex; marked by <-- HERE in m/\${ <-- HERE ([^}]+)}/ at /usr/share/perl5/Debconf/Config.pm line 30.
Setting up util-linux (2.27.1-6ubuntu3.1) ...
insserv: warning: script 'K01startencryptd' missing LSB tags and overrides
insserv: warning: script 'S100startencryptd' missing LSB tags and overrides
insserv: Service mountdevsubfs has to be enabled to start service hwclock
insserv: exiting now!
update-rc.d: error: insserv rejected the script header
dpkg: error processing package util-linux (--configure):
 subprocess installed post-installation script returned error exit status 1
 util-linux
Please tell me what is going on and how to fix it. As I said from the beginning of the post, it upgraded to 16.04 successfully. Here is the output of lsb_release -a:
No LSB modules are available.
Distributor ID: Ubuntu
Description:    Ubuntu 16.04.1 LTS
Release:        16.04
Codename:       xenial
Here is the content of /etc/apt/sources.list:
deb http://archive.ubuntu.com/ubuntu xenial main universe
deb http://archive.ubuntu.com/ubuntu xenial-updates main universe
deb http://archive.ubuntu.com/ubuntu xenial-security main universe
NOTE: As far as my understanding and after my investigation. My repositories aren't causes to this problem. WHY? Check the comment below, from 10k reputation user.
it looks like you have a lot third party repositories enabled and one of them has some broken packages in it, its quite likely that will be fixed in a few hours or days.
If you want to fix it now go in to /etc/apt/sources.list.d and comment the extra repositories out. This should get you back to the point there apt-get update works again.
When that has completed do an apt-get upgrade and then re-add the repositories one by one until the breakage comes back and you will know where its come from. Then you can report the bug to the repo maintainer and re-enable when its fixed.
Amias
  • 5,359
