On Ubuntu 16.04, I've done:
# Go to TTY with Ctrl + Alt + F1
sudo apt-get install netsurf-fb
sudo usermod -aG 'audio,input,video' "$USER"
# Logout, login.
netsurf-fb
And it fails with:
Unable to set video: Could not set console screen info fbdev
sudo didn't help either.
netsurf version 3.2.
fbi and vlc did work on the other hand.
Zanna
  • 72,312
I had a similar problem getting netsurf to run, but managed to fix it thanks to persistence and blind luck.
Problem 1: init mouse failed Solution: Add myself to the input group (the group that owns /dev/input/mice
Problem 2: Unable to set video: Could not set console screen info fbdev Solution: Install the xserver-xorg-video-fbdev and fbset packages
Problem 3: Running netsurf causes the screen to go blank and the system to hang, requiring a hard reboot Solution: I ran it in verbose mode and redirected standard error to a file, and I saw that netsurf was complaining about not being able to find DejaVuSans.ttf. I copied the file from /usr/share/fonts/truetype/dejavu to /usr/share/netsurf
Anonymous
  • 46
