I have installed Ubuntu 16.04 LTS, Linux Mint 18 and Elementary OS all on external hard drive (all OSs are installed on different partitions). I was using Linux Mint to recover some data from SD card using "Photorec" and in this process the partition on which mint was installed got fully used leaving no free space. When I restarted the computer, mint didn't allow me to log-in giving an error message that due to no free space you cannot login, hence contact your administrator.
In order to free-up some space I logged into Ubuntu and deleted some files from the partition on which mint was installed. Even after deleting files of approx 5GB the properties show that there is no free space in the said partition.
Now I don't know where these files, which I have been deleted, have gone and how to free up some space. One thing that came into my mind was that the deleted files might have gone into trash. But there was nothing in the trash of Ubuntu. I don't know how to access the trash of mint using Ubuntu to check whether deleted files have gone into mint trash folder.
Please help me freeing up some space in my mint partition using Ubuntu.
PS: As the folders of mint were locked when I logged into Ubuntu, hence I deleted the files after unlocking the folders with the help of "sudo nautilus" command.
Regards
Use Nautilus' option of seeing hidden files. Look for a file named .Trash under the root account of the OS installation and delete that one. Also look for the .Trash folder under the UID account that you used when you where working with the drive.
You can check your effective UID with the command: echo $UID. Then look at the /etc/passwd file for the UID on the Mint drive... the drive that you are trying to recover the space to.
L. D. James
  • 25,444
There is no "trash of Ubuntu", there is one trash for each user. You ran Nautilus as root with sudo nautilus therefore you have two options.
  1. Run sudo nautilus again from Ubuntu and empty the trash there.
  2. Figure out where the .Trash-0 hidden folder is in the Mint partition and manually clean it with the terminal, e.g.:
    sudo rm -rf /path/to/.Trash-0
