As in the title, plus I'm already in group dialout via:
sudo usermod -a -G dialout ben
(I restarted my PC several times since then...)
I'm using Ubuntu 16.04
File permission of the device-file:
crw-rw---- 1 root dialout 216, 0 Aug 26 22:50 /dev/rfcomm0
when I try to run:minicom or putty (as ben, not as root) I got following error:
minicom: Error opening the file »/dev/rfcomm0«: The device or ressource is busy
(same with putty)
But when I do: sudo minicom, everything is OK and works well.
(Device seems not to be busy anymore, when using sudo)
Question:
How to connect/read/write to serial port without root?
Ben
  • 752
This is an answer to my own question.
To solve the problem, I had to remove the modemmanager via:
sudo apt remove modemmanager
After a reboot, minicom (and putty) works without root!
Of course, you also need to be in the dialout group:
sudo adduser $USER dialout
I found the solution in this Ask Ubuntu answer and this Launchpad bug report.
Zanna
  • 72,312
Ben
  • 752
