New to this forum. Thank you!
Now I'm struggle to use my QCA9565 wifi card with my dualboot laptop. This is Lenovo X1 Carbon Gen3 (i7 5600u).
In Windows10 side,no problems occur.
But in ubuntu side,wifi is not working.
I'm very curious because netowrkmanager can see wireless acccess point in my home and try to connect and ask me password. But it cannot connect to network saying "Disconnected. Now you are offline."
And then I replaced qca9565 with intel 7265NGW with firmware installed. It worked fine.
What's wrong with ath9k? Please help me. I googled and tried various solution. But I couldn't. Now I know I can't do this by myself....
I attached systemctl output,journalctl output and wifi-script output. And I used liveusb (updated) to claryfy what the problem is. Almost all settings and packages might be vanilla. Anybody know solution?
Thanks in advance!
systemctl output
journalctl output
########## wireless info START ##########
Report from: 25 Aug 2016 17:34 UTC +0000
Booted last: 25 Aug 2016 00:00 UTC +0000
Script from: 08 Jul 2016 02:16 UTC +0000
##### release ###########################
Distributor ID: Ubuntu
Description: Ubuntu 16.04.1 LTS
Release: 16.04
Codename: xenial
##### kernel ############################
Linux 4.4.0-31-generic #50-Ubuntu SMP Wed Jul 13 00:07:12 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
Parameters: file=/cdrom/preseed/ubuntu.seed, boot=casper, quiet, splash, ---
##### desktop ###########################
Ubuntu
##### lspci #############################
00:19.0 Ethernet controller [0200]: Intel Corporation Ethernet Connection (3) I218-LM [8086:15a2] (rev 03)
Subsystem: Lenovo Ethernet Connection (3) I218-LM [17aa:2227]
Kernel driver in use: e1000e
04:00.0 Network controller [0280]: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter [168c:0036] (rev 01)
Subsystem: Lenovo QCA9565 / AR9565 Wireless Network Adapter [17aa:4026]
Kernel driver in use: ath9k
##### lsusb #############################
Bus 001 Device 002: ID 8087:8001 Intel Corp.
Bus 003 Device 005: ID 0b95:1790 ASIX Electronics Corp. AX88179 Gigabit Ethernet
Bus 003 Device 004: ID 8564:4000 Transcend Information, Inc. RDF8
Bus 003 Device 003: ID 067b:2773 Prolific Technology, Inc. PL2773 SATAII bridge controller
Bus 003 Device 002: ID 2109:0812 VIA Labs, Inc. VL812 Hub
Bus 003 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 002 Device 006: ID 04f2:b45d Chicony Electronics Co., Ltd
Bus 002 Device 007: ID 0cf3:3004 Atheros Communications, Inc. AR3012 Bluetooth 4.0
Bus 002 Device 004: ID 138a:0017 Validity Sensors, Inc. Fingerprint Reader
Bus 002 Device 003: ID 04f3:012d Elan Microelectronics Corp.
Bus 002 Device 002: ID 2109:2811 VIA Labs, Inc. Hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
##### PCMCIA card info ##################
##### rfkill ############################
0: tpacpi_bluetooth_sw: Bluetooth
Soft blocked: no
Hard blocked: no
1: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
2: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
##### lsmod #############################
ath9k 143360 0
ath9k_common 36864 1 ath9k
ath9k_hw 466944 2 ath9k_common,ath9k
ath 32768 3 ath9k_common,ath9k,ath9k_hw
mac80211 737280 1 ath9k
ath3k 20480 0
cfg80211 565248 4 ath,ath9k_common,ath9k,mac80211
bluetooth 520192 30 bnep,ath3k,btbcm,btrtl,btusb,rfcomm,btintel
wmi 20480 0
##### interfaces ########################
auto lo
iface lo inet loopback
##### ifconfig ##########################
enp0s25 Link encap:Ethernet HWaddr <MAC 'enp0s25' [IF1]>
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
Interrupt:20 Memory:e1100000-e1120000
enx<IF from MAC [IF2]> Link encap:Ethernet HWaddr <MAC 'enx<IF from MAC [IF2]>' [IF2]>
RX packets:7707 errors:0 dropped:0 overruns:0 frame:0
TX packets:6385 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:7861781 (7.8 MB) TX bytes:746654 (746.6 KB)
wlp4s0 Link encap:Ethernet HWaddr <MAC 'wlp4s0' [IF3]>
RX packets:15 errors:0 dropped:0 overruns:0 frame:0
TX packets:32 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:3427 (3.4 KB) TX bytes:6392 (6.3 KB)
##### iwconfig ##########################
enx<IF from MAC [IF2]> no wireless extensions.
lo no wireless extensions.
enp0s25 no wireless extensions.
wlp4s0 IEEE 802.11bgn ESSID:off/any
Mode:Managed Access Point: Not-Associated Tx-Power=15 dBm
Retry short limit:7 RTS thr:off Fragment thr:off
Power Management:off
##### route #############################
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
##### resolv.conf #######################
nameserver 127.0.1.1
##### network managers ##################
Installed:
NetworkManager
Running:
root 3902 1 0 17:24 ? 00:00:00 /usr/sbin/NetworkManager --no-daemon
##### NetworkManager info ###############
GENERAL.DEVICE: wlp4s0
GENERAL.TYPE: wifi
GENERAL.NM-TYPE: NMDeviceWifi
GENERAL.VENDOR: Qualcomm Atheros
GENERAL.PRODUCT: QCA9565 / AR9565 Wireless Network Adapter
GENERAL.DRIVER: ath9k
GENERAL.DRIVER-VERSION: 4.4.0-31-generic
GENERAL.FIRMWARE-VERSION: N/A
GENERAL.HWADDR: <MAC 'wlp4s0' [IF3]>
GENERAL.MTU: 0
GENERAL.STATE: 30 (disconnected)
GENERAL.REASON: 0 (No reason given)
GENERAL.UDI: /sys/devices/pci0000:00/0000:00:1c.1/0000:04:00.0/net/wlp4s0
GENERAL.IP-IFACE:
GENERAL.IS-SOFTWARE: no
GENERAL.NM-MANAGED: yes
GENERAL.AUTOCONNECT: yes
GENERAL.FIRMWARE-MISSING: no
GENERAL.NM-PLUGIN-MISSING: no
GENERAL.PHYS-PORT-ID: --
GENERAL.CONNECTION: --
GENERAL.CON-UUID: --
GENERAL.CON-PATH: --
GENERAL.METERED: unknown
CAPABILITIES.CARRIER-DETECT: no
CAPABILITIES.SPEED: unknown
CAPABILITIES.IS-SOFTWARE: no
WIFI-PROPERTIES.WEP: yes
WIFI-PROPERTIES.WPA: yes
WIFI-PROPERTIES.WPA2: yes
WIFI-PROPERTIES.TKIP: yes
WIFI-PROPERTIES.CCMP: yes
WIFI-PROPERTIES.AP: yes
WIFI-PROPERTIES.ADHOC: yes
WIFI-PROPERTIES.2GHZ: yes
WIFI-PROPERTIES.5GHZ: no
CONNECTIONS.AVAILABLE-CONNECTION-PATHS: /org/freedesktop/NetworkManager/Settings/{2}
CONNECTIONS.AVAILABLE-CONNECTIONS[1]: ecd441e2-ff09-4e3c-a468-cc293f94a191 | aterm-8cb52f-g
GENERAL.DEVICE: enp0s25
GENERAL.TYPE: ethernet
GENERAL.NM-TYPE: NMDeviceEthernet
GENERAL.VENDOR: Intel Corporation
GENERAL.PRODUCT: Ethernet Connection (3) I218-LM
GENERAL.DRIVER: e1000e
GENERAL.DRIVER-VERSION: 3.2.6-k
GENERAL.FIRMWARE-VERSION: 0.2-4
GENERAL.HWADDR: <MAC 'enp0s25' [IF1]>
GENERAL.MTU: 1500
GENERAL.STATE: 20 (unavailable)
GENERAL.REASON: 2 (Device is now managed)
GENERAL.UDI: /sys/devices/pci0000:00/0000:00:19.0/net/enp0s25
GENERAL.IP-IFACE:
CAPABILITIES.CARRIER-DETECT: yes
WIRED-PROPERTIES.CARRIER: off
GENERAL.DEVICE: enx<IF from MAC [IF2]>
GENERAL.VENDOR: ASIX Elec. Corp.
GENERAL.PRODUCT: AX88179
GENERAL.DRIVER: ax88179_178a
GENERAL.HWADDR: <MAC 'enx<IF from MAC [IF2]>' [IF2]>
GENERAL.MTU: 1500
GENERAL.REASON: 40 (Carrier/link changed)
GENERAL.UDI: /sys/devices/pci0000:00/0000:00:14.0/usb3/3-2/3-2.4/3-2.4:1.0/net/enx<IF from MAC [IF2]>
GENERAL.IP-IFACE:
CAPABILITIES.SPEED: 1000 Mb/s
SSID BSSID MODE CHAN FREQ RATE SIGNAL BARS SECURITY ACTIVE *
aterm-fc8e9d-g <MAC 'aterm-fc8e9d-g' [AC2]> Infra 9 2452 MHz 54 Mbit/s 100 ▂▄▆█ WPA1 WPA2 no
aterm-fc8e9d-gw <MAC 'aterm-fc8e9d-gw' [AC3]> Infra 9 2452 MHz 54 Mbit/s 100 ▂▄▆█ WEP no
001D73A97C90_G <MAC '001D73A97C90_G' [AC1]> Infra 1 2412 MHz 54 Mbit/s 77 ▂▄▆_ -- no
WARPSTAR-535F1E <MAC 'WARPSTAR-535F1E' [AC6]> Infra 11 2462 MHz 54 Mbit/s 57 ▂▄▆_ WPA1 WPA2 no
aterm-8cb52f-g <MAC 'aterm-8cb52f-g' [AC4]> Infra 10 2457 MHz 54 Mbit/s 55 ▂▄__ WPA1 WPA2 no
BCW710J-72C6E-G <MAC 'BCW710J-72C6E-G' [AN6]> Infra 11 2462 MHz 54 Mbit/s 49 ▂▄__ WPA1 WPA2 no
BCW710J-72C6A-G <MAC 'BCW710J-72C6A-G' [AC5]> Infra 11 2462 MHz 54 Mbit/s 29 ▂___ WPA1 WPA2 no
##### NetworkManager.state ##############
[main]
NetworkingEnabled=true
WirelessEnabled=true
WWANEnabled=true
##### NetworkManager.conf ###############
[main]
plugins=ifupdown,keyfile,ofono
dns=dnsmasq
[ifupdown]
managed=false
##### NetworkManager profiles ###########
[[/etc/NetworkManager/system-connections/aterm-8cb52f-g]] (600 root)
[connection] id=aterm-8cb52f-g | type=wifi | permissions=user:ubuntu:;
[wifi] mac-address=<MAC 'wlp4s0' [IF3]> | mac-address-blacklist= | ssid=aterm-8cb52f-g
[ipv4] method=auto
[ipv6] method=auto
##### iw reg get ########################
Region: Etc/UTC (based on set time zone)
country 00: DFS-UNSET
(2402 - 2472 @ 40), (N/A, 20), (N/A)
(2457 - 2482 @ 40), (N/A, 20), (N/A), NO-IR
(2474 - 2494 @ 20), (N/A, 20), (N/A), NO-OFDM, NO-IR
(5170 - 5250 @ 80), (N/A, 20), (N/A), NO-IR
(5250 - 5330 @ 80), (N/A, 20), (0 ms), DFS, NO-IR
(5490 - 5730 @ 160), (N/A, 20), (0 ms), DFS, NO-IR
(5735 - 5835 @ 80), (N/A, 20), (N/A), NO-IR
(57240 - 63720 @ 2160), (N/A, 0), (N/A)
##### iwlist channels ###################
enx<IF from MAC [IF2]> no frequency information.
lo no frequency information.
enp0s25 no frequency information.
wlp4s0 13 channels in total; available frequencies :
Channel 01 : 2.412 GHz
Channel 02 : 2.417 GHz
Channel 03 : 2.422 GHz
Channel 04 : 2.427 GHz
Channel 05 : 2.432 GHz
Channel 06 : 2.437 GHz
Channel 07 : 2.442 GHz
Channel 08 : 2.447 GHz
Channel 09 : 2.452 GHz
Channel 10 : 2.457 GHz
Channel 11 : 2.462 GHz
Channel 12 : 2.467 GHz
Channel 13 : 2.472 GHz
##### iwlist scan #######################
enx<IF from MAC [IF2]> Interface doesn't support scanning.
lo Interface doesn't support scanning.
enp0s25 Interface doesn't support scanning.
Channel occupancy:
1 APs on Frequency:2.412 GHz (Channel 1)
2 APs on Frequency:2.452 GHz (Channel 9)
1 APs on Frequency:2.457 GHz (Channel 10)
2 APs on Frequency:2.462 GHz (Channel 11)
wlp4s0 Scan completed :
Cell 01 - Address: <MAC '001D73A97C90_G' [AC1]>
Channel:1
Quality=55/70 Signal level=-55 dBm
Encryption key:off
ESSID:"001D73A97C90_G"
Bit Rates:1 Mb/s; 2 Mb/s; 5.5 Mb/s; 11 Mb/s
Bit Rates:6 Mb/s; 9 Mb/s; 12 Mb/s; 18 Mb/s; 24 Mb/s
36 Mb/s; 48 Mb/s; 54 Mb/s
Mode:Master
Extra:tsf=000000d3e4a5c4c4
Extra: Last beacon: 12ms ago
Cell 02 - Address: <MAC 'aterm-fc8e9d-g' [AC2]>
Channel:9
Quality=70/70 Signal level=-13 dBm
Encryption key:on
ESSID:"aterm-fc8e9d-g"
Bit Rates:1 Mb/s; 2 Mb/s; 5.5 Mb/s; 11 Mb/s; 6 Mb/s
Bit Rates:24 Mb/s; 36 Mb/s; 48 Mb/s; 54 Mb/s
Mode:Master
Extra:tsf=0000003421b4eae1
IE: IEEE 802.11i/WPA2 Version 1
Group Cipher : CCMP
Pairwise Ciphers (1) : CCMP
Authentication Suites (1) : PSK
IE: WPA Version 1
Group Cipher : CCMP
Cell 03 - Address: <MAC 'aterm-fc8e9d-gw' [AC3]>
Channel:9
Quality=70/70 Signal level=-12 dBm
Encryption key:on
ESSID:"aterm-fc8e9d-gw"
Mode:Master
Extra:tsf=0000003421b5c1f7
Cell 04 - Address: <MAC 'aterm-8cb52f-g' [AC4]>
Channel:10
Quality=43/70 Signal level=-67 dBm
Encryption key:on
ESSID:"aterm-8cb52f-g"
Mode:Master
Extra:tsf=000000341c05243d
IE: WPA Version 1
Group Cipher : CCMP
Group Cipher : CCMP
Cell 05 - Address: <MAC 'BCW710J-72C6A-G' [AC5]>
Channel:11
Quality=27/70 Signal level=-83 dBm
Encryption key:on
ESSID:"BCW710J-72C6A-G"
Bit Rates:1 Mb/s; 2 Mb/s; 5.5 Mb/s; 11 Mb/s; 18 Mb/s
24 Mb/s; 36 Mb/s; 54 Mb/s
Bit Rates:6 Mb/s; 9 Mb/s; 12 Mb/s; 48 Mb/s
Mode:Master
Extra:tsf=000000049192fd0c
Extra: Last beacon: 12652ms ago
Group Cipher : TKIP
Pairwise Ciphers (2) : CCMP TKIP
IE: WPA Version 1
Group Cipher : TKIP
Cell 06 - Address: <MAC 'WARPSTAR-535F1E' [AC6]>
Channel:11
Quality=44/70 Signal level=-66 dBm
Encryption key:on
ESSID:"WARPSTAR-535F1E"
Mode:Master
Extra:tsf=00000953ce827184
Extra: Last beacon: 7940ms ago
Group Cipher : CCMP
IE: WPA Version 1
Group Cipher : CCMP
##### module infos ######################
[ath9k]
filename: /lib/modules/4.4.0-31-generic/kernel/drivers/net/wireless/ath/ath9k/ath9k.ko
license: Dual BSD/GPL
description: Support for Atheros 802.11n wireless LAN cards.
author: Atheros Communications
srcversion: 323EDC06388A3D0920FD7FC
depends: mac80211,ath9k_hw,ath9k_common,cfg80211,ath
intree: Y
vermagic: 4.4.0-31-generic SMP mod_unload modversions
parm: debug:Debugging mask (uint)
parm: nohwcrypt:Disable hardware encryption (int)
parm: blink:Enable LED blink on activity (int)
parm: led_active_high:Invert LED polarity (int)
parm: btcoex_enable:Enable wifi-BT coexistence (int)
parm: bt_ant_diversity:Enable WLAN/BT RX antenna diversity (int)
parm: ps_enable:Enable WLAN PowerSave (int)
parm: use_chanctx:Enable channel context for concurrency (int)
[ath9k_common]
filename: /lib/modules/4.4.0-31-generic/kernel/drivers/net/wireless/ath/ath9k/ath9k_common.ko
description: Shared library for Atheros wireless 802.11n LAN cards.
srcversion: 6FBD9F8A613FDFA282AB4FE
depends: ath9k_hw,cfg80211,ath
intree: Y
[ath9k_hw]
filename: /lib/modules/4.4.0-31-generic/kernel/drivers/net/wireless/ath/ath9k/ath9k_hw.ko
srcversion: BF9F4930086BABAAF3CD9BA
depends: ath
intree: Y
[ath]
filename: /lib/modules/4.4.0-31-generic/kernel/drivers/net/wireless/ath/ath.ko
description: Shared library for Atheros wireless LAN cards.
srcversion: 3FCDBF7CE71CB8FB980D59D
depends: cfg80211
intree: Y
[mac80211]
filename: /lib/modules/4.4.0-31-generic/kernel/net/mac80211/mac80211.ko
license: GPL
description: IEEE 802.11 subsystem
srcversion: 2FFAEED0245CA1D97FE1E44
depends: cfg80211
intree: Y
parm: minstrel_vht_only:Use only VHT rates when VHT is supported by sta. (bool)
parm: max_nullfunc_tries:Maximum nullfunc tx tries before disconnecting (reason 4). (int)
parm: max_probe_tries:Maximum probe tries before disconnecting (reason 4). (int)
parm: beacon_loss_count:Number of beacon intervals before we decide beacon was lost. (int)
parm: probe_wait_ms:Maximum time(ms) to wait for probe response before disconnecting (reason 4). (int)
parm: ieee80211_default_rc_algo:Default rate control algorithm for mac80211 to use (charp)
[ath3k]
filename: /lib/modules/4.4.0-31-generic/kernel/drivers/bluetooth/ath3k.ko
firmware: ath3k-1.fw
license: GPL
version: 1.0
description: Atheros AR30xx firmware driver
srcversion: 2B85DCB887D9376A61652DD
depends: bluetooth
intree: Y
[cfg80211]
filename: /lib/modules/4.4.0-31-generic/kernel/net/wireless/cfg80211.ko
description: wireless configuration support
license: GPL
author: Johannes Berg
srcversion: 25A45701AAA64DAC1E47D9D
depends:
intree: Y
parm: ieee80211_regdom:IEEE 802.11 regulatory domain code (charp)
parm: cfg80211_disable_40mhz_24ghz:Disable 40MHz support in the 2.4GHz band (bool)
##### module parameters #################
[ath9k]
blink: 0
bt_ant_diversity: 0
btcoex_enable: 0
led_active_high: -1
nohwcrypt: 0
ps_enable: 0
use_chanctx: 0
[mac80211]
beacon_loss_count: 7
ieee80211_default_rc_algo: minstrel_ht
max_nullfunc_tries: 2
max_probe_tries: 5
minstrel_vht_only: Y
probe_wait_ms: 500
[cfg80211]
cfg80211_disable_40mhz_24ghz: N
ieee80211_regdom: 00
##### /etc/modules ######################
##### modprobe options ##################
[/etc/modprobe.d/blacklist-ath_pci.conf]
blacklist ath_pci
[/etc/modprobe.d/blacklist.conf]
blacklist evbug
blacklist usbmouse
blacklist usbkbd
blacklist eepro100
blacklist de4x5
blacklist eth1394
blacklist snd_intel8x0m
blacklist snd_aw2
blacklist i2c_i801
blacklist prism54
blacklist bcm43xx
blacklist garmin_gps
blacklist asus_acpi
blacklist snd_pcsp
blacklist pcspkr
blacklist amd76x_edac
[/etc/modprobe.d/blacklist-rare-network.conf]
alias net-pf-3 off
alias net-pf-6 off
alias net-pf-9 off
alias net-pf-11 off
alias net-pf-12 off
alias net-pf-19 off
alias net-pf-21 off
alias net-pf-36 off
[/etc/modprobe.d/iwlwifi.conf]
remove iwlwifi \
(/sbin/lsmod | grep -o -e ^iwlmvm -e ^iwldvm -e ^iwlwifi | xargs /sbin/rmmod) \
&& /sbin/modprobe -r mac80211
[/etc/modprobe.d/mlx4.conf]
softdep mlx4_core post: mlx4_en
##### rc.local ##########################
exit 0
##### pm-utils ##########################
##### udev rules ########################
##### dmesg #############################
[ 18.069361] ath: phy0: WB335 2-ANT card detected
[ 18.069363] ath: phy0: Set BT/WLAN RX diversity capability
[ 18.078232] ath: phy0: Enable LNA combining
[ 18.080246] ath: phy0: ASPM enabled: 0x43
[ 18.080250] ath: EEPROM regdomain: 0x6a
[ 18.080251] ath: EEPROM indicates we should expect a direct regpair map
[ 18.080253] ath: Country alpha2 being used: 00
[ 18.080254] ath: Regpair used: 0x6a
[ 18.279871] ath9k 0000:04:00.0 wlp4s0: renamed from wlan0
[ 19.294493] ax88179_178a 3-2.4:1.0 eth0: register 'ax88179_178a' at usb-0000:00:14.0-2.4, ASIX AX88179 USB 3.0 Gigabit Ethernet, <MAC 'enx<IF from MAC [IF2]>' [IF2]>
[ 19.309738] ax88179_178a 3-2.4:1.0 enx<IF from MAC [IF2]>: renamed from eth0
[ 19.772559] IPv6: ADDRCONF(NETDEV_UP): wlp4s0: link is not ready (repeated 2 times)
[ 19.787869] IPv6: ADDRCONF(NETDEV_UP): enp0s25: link is not ready (repeated 2 times)
[ 20.094512] IPv6: ADDRCONF(NETDEV_UP): enx<IF from MAC [IF2]>: link is not ready (repeated 2 times)
[ 20.601602] IPv6: ADDRCONF(NETDEV_UP): wlp4s0: link is not ready
[ 22.873028] ax88179_178a 3-2.4:1.0 enx<IF from MAC [IF2]>: ax88179 - Link status is: 1
[ 22.879523] IPv6: ADDRCONF(NETDEV_CHANGE): enx<IF from MAC [IF2]>: link becomes ready
[ 378.478341] ax88179_178a 3-2.4:1.0 enx<IF from MAC [IF2]>: ax88179 - Link status is: 0
[ 525.190441] wlp4s0: authenticate with <MAC 'aterm-8cb52f-g' [AC4]>
[ 525.208818] wlp4s0: send auth to <MAC 'aterm-8cb52f-g' [AC4]> (try 1/3)
[ 525.837817] wlp4s0: send auth to <MAC 'aterm-8cb52f-g' [AC4]> (try 2/3)
[ 526.212070] wlp4s0: authenticated
[ 526.245769] wlp4s0: associate with <MAC 'aterm-8cb52f-g' [AC4]> (try 1/3)
[ 526.850162] wlp4s0: associate with <MAC 'aterm-8cb52f-g' [AC4]> (try 2/3)
[ 527.849800] wlp4s0: associate with <MAC 'aterm-8cb52f-g' [AC4]> (try 3/3)
[ 528.248125] wlp4s0: RX AssocResp from <MAC 'aterm-8cb52f-g' [AC4]> (capab=0x411 status=0 aid=2)
[ 528.248231] wlp4s0: associated
[ 528.248239] IPv6: ADDRCONF(NETDEV_CHANGE): wlp4s0: link becomes ready
[ 528.261451] ath: EEPROM regdomain: 0x8188
[ 528.261452] ath: EEPROM indicates we should expect a country code
[ 528.261453] ath: doing EEPROM country->regdmn map search
[ 528.261454] ath: country maps to regdmn code: 0x40
[ 528.261455] ath: Country alpha2 being used: JP
[ 528.261455] ath: Regpair used: 0x40
[ 528.261456] ath: regdomain 0x8188 dynamically updated by country IE
[ 575.068482] wlp4s0: deauthenticating from <MAC 'aterm-8cb52f-g' [AC4]> by local choice (Reason: 3=DEAUTH_LEAVING)
########## wireless info END ############
