running:
ubuntu 14.04 trusty 64bit.
My current version is:
itamar /v/l/a/lists λ git --version
git version 1.9.1
I tried: sudo apt-get update; sudo apt-get install git and it didn't work.
I tried: sudo apt-get purge git; sudo apt-get install git and still it installed 1.9.1.
not just that, somehow it uninstalled Atom and Nylas along with git and some other git related packages. I would love to know why it did that also. Below is the output from the purge process.
itamar ~ λ sudo apt-get purge git
[sudo] password for itamar:
Reading package lists... Done
Building dependency tree
The following packages will be REMOVED:
atom* git* git-cola* git-core* gitk* nylas*
0 upgraded, 0 newly installed, 6 to remove and 0 not upgraded.
After this operation, 543 MB disk space will be freed.
Do you want to continue? [Y/n] y
(Reading database ... 332614 files and directories currently      installed.)
Removing atom (1.8.0) ...
dpkg: warning: while removing atom, directory    '/usr/share/atom/resources/app/apm' not empty so not removed
Removing nylas (0.4.49) ...
Purging configuration files for nylas (0.4.49) ...
Removing git-cola (1.9.3-1) ...
Purging configuration files for git-cola (1.9.3-1) ...
Removing gitk (1:1.9.1-1ubuntu0.3) ...
Removing git-core (1:1.9.1-1ubuntu0.3) ...
Removing git (1:1.9.1-1ubuntu0.3) ...
Purging configuration files for git (1:1.9.1-1ubuntu0.3) ...
Processing triggers for gnome-menus (3.10.1-0ubuntu2) ...
Processing triggers for desktop-file-utils (0.22-1ubuntu1) ...
Processing triggers for bamfdaemon (0.5.1+14.04.20140409-0ubuntu1) ...
Rebuilding /usr/share/applications/bamf-2.index...
Processing triggers for mime-support (3.54ubuntu1.1) ...
Processing triggers for hicolor-icon-theme (0.13-1) ...
Processing triggers for man-db (2.6.7.1-1ubuntu1) ...
So, I've found that there's a Ubuntu Git Maintainers team ppa in launchpad.
Seems legit and it worked, my git is now 2.9but i really don't see why this wouldn't be included in ubuntu in the first place? this is basic stuff. And don't tell me that it's because i'm running 14.04 and not 16.04 because 14.04 is still the majority of ubuntu users.
It's weird.
