According to the official docs you just download a pre-compiled binary but this would leave things like man documentation and autocompletion not working.
- 207,228
- 349
You can use this PPA to install hub as a package:
sudo add-apt-repository ppa:cpick/hub
sudo apt-get update
sudo apt-get install hub
- 359
Updated answer
As PatKilg pointed out in the comment, the Hub maintainers now discourage using the snap.
Original answer
Hub is available as a snap now. https://snapcraft.io/hub
You can install it with sudo snap install --classic hub.
- 199
Install Hub
Download Hub from Github
Extract it. I've extracted it to
Apps/directory in my home and renamed it tohub-linux. So, in my setup, the complete path to thebinfolder is/home/anwar/Apps/hub-linux/binNow open the
~/.bashrcfile and add the hub binary path to the$PATHenvironment variable. Adding a line like below will work.
### Adds Hub-linux
export PATH="$PATH:$HOME/Apps/hub-linux/bin/"
Don't forget to to use actual path in your setup
Add the Bash Completion
To add bash completion, we need to tell bash to source the completion file came with hub-archive. The completion file is in the etc folder of the extracted hub folder. To do so,
Open the .bashrc and write there these lines
### Load Hub Linux bash completion
if [ -f $HOME/Apps/hub-linux/etc/hub.bash_completion.sh ] ; then
. $HOME/Apps/hub-linux/etc/hub.bash_completion.sh
fi
Don't forget to replace the exact path of hub.bash_completion.sh file according to your setup
Now, You should be able to use hub bash completion
Add Hub's manpage to man database
Hub's man page actually came with the archive. It's in the share folder. To add the manpage, we need to put it in the man page directory.
To do so, Open a terminal and cd to the extracted hub archive. Assuming your current directory is in the same directory where hub's bin, share, README.md reside, use this command to copy the manpage
sudo cp -r share/ /usr/
sudo chmod 644 /usr/share/man/man1/hub.1
Now you can use hub's manual page using man hub command.
If you can't immediately use man hub, use sudo updatedb to refresh man db of the system.
This script should do the job on Ubuntu 16.04 with zsh.
# Install binary and documentation
wget https://github.com/github/hub/releases/download/v2.2.9/hub-linux-amd64-2.2.9.tgz
tar zvxvf hub-linux-amd64-2.2.9.tgz
sudo ./hub-linux-amd64-2.2.9/install
# Setup autocomplete for zsh:
mkdir -p ~/.zsh/completions
mv ./hub-linux-amd64-2.2.9/etc/hub.zsh_completion ~/.zsh/completions/_hub
echo "fpath=(~/.zsh/completions $fpath)" >> ~/.zshrc
echo "autoload -U compinit && compinit" >> ~/.zshrc
# add alias
echo "eval "$(hub alias -s)"" >> ~/.zshrc
# Cleanup
rm -rf hub-linux-amd64-2.2.9
Alternatively for Ubuntu 16.04 with bash:
# Setup autocomplete for bash:
mkdir -p ~/.bash/completions
mv ./hub-linux-amd64-2.2.9/etc/hub.bash_completion.sh ~/.bash/completions/_hub
echo "if [ -f ~/.bash/completions/_hub ]; then" >> ~/.bashrc
echo " . ~/.bash/completions/_hub" >> ~/.bashrc
echo "fi" >> ~/.bashrc
# add alias
echo "eval "$(hub alias -s)"" >> ~/.bashrc
# Cleanup
Test installation:
hub version
- 349
