Here is the whole error report. I already ran into trouble once and had to reinstall the Ubuntu croot.
Entering /mnt/stateful_partition/crouton/chroots/precise...
_XSERVTransmkdir: Owner of /tmp/.X11-unix should be set to root
X.Org X Server 1.11.3
Release Date: 2011-12-16
X Protocol Version 11, Revision 0
Build Operating System: Linux 2.6.42-61-generic x86_64 Ubuntu
Current Operating System: Linux localhost 3.8.11 #1 SMP Tue Aug 2 21:07:18 PDT 2016 x86_64
Kernel command line: cros_secure console= loglevel=7 init=/sbin/init cros_secure oops=panic panic=-1 root=/dev/dm-0 rootwait ro dm_verity.error_behavior=3 dm_verity.max_bios=-1 dm_verity.dev_wait=1 dm="1 vroot none ro 1,0 2506752 verity payload=PARTUUID=099cc490-7c10-d544-8e14-62ec05a5c497/PARTNROFF=1 hashtree=PARTUUID=099cc490-7c10-d544-8e14-62ec05a5c497/PARTNROFF=1 hashstart=2506752 alg=sha1 root_hexdigest=25db33872914fd7b5c8ca0df301c145a839f948b salt= e3821ceded498fdebc583fc952517083a5e5798641d92e6a21519321dbef9a49" noinitrd vt.global_cursor_default=0 kern_guid=099cc490-7c10-d544-8e14-62ec05a5c497 add_efi_memmap boot=local noresume noswap i915.modeset=1 tpm_tis.force=1 tpm_tis.interrupts=0 nmi_watchdog=panic,lapic iTCO_vendor_support.vendorsupport=3
Build Date: 12 February 2015 02:49:01PM
xorg-server 2:1.11.4-0ubuntu10.17 (For technical support please see )
Current version of pixman: 0.30.2
Before reporting problems, check
to make sure that you have the latest version.
Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(++) Log file: "/tmp/Xorg.crouton.1.log", Time: Wed Aug 24 23:56:55 2016
(==) Using system config directory "/usr/share/X11/xorg.conf.d"
Fatal server error:
xf86EnableIOPorts: failed to set IOPL for I/O (Operation not permitted)
Please consult the The X.Org Foundation support
Please also check the log file at "/tmp/Xorg.crouton.1.log" for additional information.
ddxSigGiveUp: Closing log
Server terminated with error (1). Closing log file.
/usr/bin/xinit: giving up
/usr/bin/xinit: unable to connect to X server: No such file or directory
/usr/bin/xinit: server error
Unmounting /mnt/stateful_partition/crouton/chroots/precise...
chronos@localhost / $ sudo startunity
Kernel command line: cros_secure console= loglevel=7 init=/sbin/init cros_secure oops=panic panic=-1 root=/dev/dm-0 rootwait ro dm_verity.error_behavior=3 dm_verity.max_bios=-1 dm_verity.dev_wait=1 dm="1 vroot none ro 1,0 2506752 verity payload=PARTUUID=099cc490-7c10-d544-8e14-62ec05a5c497/PARTNROFF=1 hashtree=PARTUUID=099cc490-7c10-d544-8e14-62ec05a5c497/PARTNROFF=1 hashstart=2506752 alg=sha1 root_hexdigest=25db33872914fd7b5c8ca0df301c145a839f948b salt=e3821ceded498fdebc583fc952517083a5e5798641d92e6a21519321dbef9a49" noinitrd vt.global_cursor_default=0 kern_guid=099cc490-7c10-d544-8e14-62ec05a5c497 add_efi_memmap boot=local noresume noswap i915.modeset=1 tpm_tis.force=1 tpm_tis.interrupts=0 nmi_watchdog=panic,lapic iTCO_vendor_support.vendorsupport=3
(++) Log file: "/tmp/Xorg.crouton.1.log", Time: Thu Aug 25 00:00:51 2016
Fatal server error:
at
for help.
