I have a SSD: Samsung 850 EVO 120 GB with Ubuntu 16.04 installed on it.
I want to make sure that it is aligned properly.
Here's the disk info & structure (output was trimmed for readability):
$ sudo fdisk -l
Disk /dev/sda: 111.8 GiB, 120034123776 bytes, 234441648 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
Disk identifier: 0xa2b6933a
Device Boot Start End Sectors Size Id Type
/dev/sda1 * 2048 3999743 3997696 1.9G 83 Linux
/dev/sda2 4001790 202440703 198438914 94.6G 5 Extended
/dev/sda5 4001792 35999743 31997952 15.3G 83 Linux
/dev/sda6 36001792 202440703 166438912 79.4G 83 Linux
Using parted it told me that sda2 is not aligned properly:
$ sudo parted /dev/sda align-check opt
Partition number? 1
1 aligned
$ sudo parted /dev/sda align-check opt 2
2 not aligned
$ sudo parted /dev/sda align-check opt 5
5 aligned
$ sudo parted /dev/sda align-check opt 6
6 aligned
Is this OK? I think that the fact that sda2 is Extended, then actually everything's OK.
