UPDATE AT BOTTOM
My Ubuntu partition was running low on free space, so I decided to shrink the Windows partition down to 190GiB from about 400GiB. After shrinking there was still about half of it which was not used.
After shrinking (with Gparted) the Windows 10 partition (on /dev/sda4) Windows Boot Manager (on /dev/sda2) did not work. I also added the "boot" flag.
I have no clue what is wrong. If any information is needed, please answer how to get that information.
I think the Windows partition was efi before the shrink, but i am not sure.
BootInfo file of boot-repair with recommended options:
http://paste2.org/AfadHKG1
File gparted_details:
GParted 0.25.0 --enable-libparted-dmraid --enable-online-resize
Libparted 3.2
Shrink /dev/sda4 from 393.45 GiB to 190.43 GiB  00:05:05    ( SUCCESS )
calibrate /dev/sda4  00:00:03    ( SUCCESS )
path: /dev/sda4 (partition)
start: 1900544
end: 827034367
size: 825133824 (393.45 GiB)
check file system on /dev/sda4 for errors and (if possible) fix them  00:00:33    ( SUCCESS )
ntfsresize -i -f -v /dev/sda4  00:00:33    ( SUCCESS )
ntfsresize v2015.3.14AR.1 (libntfs-3g)
Device name : /dev/sda4
NTFS volume version: 3.1
Cluster size : 4096 bytes
Current volume size: 422468514304 bytes (422469 MB)
Current device size: 422468517888 bytes (422469 MB)
Checking for bad sectors ...
Checking filesystem consistency ...
100.00 percent completed
Accounting clusters ...
Space in use : 100204 MB (23,7%)
Collecting resizing constraints ...
Estimating smallest shrunken size supported ...
File feature Last used at By inode
Multi-Record : 247041 MB 560736
$MFTMirr : 1 MB 1
Compressed : 251592 MB 526808
Sparse : 137684 MB 35
Ordinary : 251593 MB 25298
You might resize at 100203016192 bytes or 100204 MB (freeing 322265 MB).
Please make a test run using both the -n and -s options before real resizing!
shrink file system  00:04:18    ( SUCCESS )
run simulation  00:00:35    ( SUCCESS )
ntfsresize --force --force -s 204474417152 --no-action /dev/sda4  00:00:35    ( SUCCESS )
New volume size : 204474413568 bytes (204475 MB)
Needed relocations : 1918076 (7857 MB)
Schedule chkdsk for NTFS consistency check at Windows boot time ...
Resetting $LogFile ... (this might take a while)
Relocating needed data ...
Updating $BadClust file ...
Updating $Bitmap file ...
Updating Boot record ...
The read-only test run ended successfully.
real resize  00:03:43    ( SUCCESS )
ntfsresize --force --force -s 204474417152 /dev/sda4  00:03:43    ( SUCCESS )
Syncing device ...
Successfully resized NTFS on device '/dev/sda4'.
You can go on to shrink the device for example with Linux fdisk.
IMPORTANT: When recreating the partition, make sure that you
1) create it at the same disk sector (use sector as the unit!)
2) create it with the same partition type (usually 7, HPFS/NTFS)
3) do not make it smaller than the new NTFS filesystem size
4) set the bootable flag for the partition if it existed before
Otherwise you won't be able to access NTFS or can't boot from the disk!
If you make a mistake and don't have a partition table backup then you
can recover the partition table by TestDisk or Parted's rescue mode.
shrink partition from 393.45 GiB to 190.43 GiB  00:00:11    ( SUCCESS )
old start: 1900544
old end: 827034367
old size: 825133824 (393.45 GiB)
new start: 1900544
new end: 401264639
new size: 399364096 (190.43 GiB)
Output of sudo mount /dev/sda2:
mount: /dev/sda2 is already mounted or /boot/efi busy
/dev/sda2 is already mounted on /boot/efi
Output of `sudo mount /dev/sda4
mount: can't find /dev/sda4 in /etc/fstab
Output of sudo parted -l:
Model: ATA HGST HTS545050A7 (scsi)
Disk /dev/sda: 500GB
Sector size (logical/physical): 512B/4096B
Partition Table: gpt
Disk Flags:
Number  Start   End    Size    File system     Name                          Flags
 1      1049kB  524MB  523MB   ntfs            Basic data partition          hidden, diag
 2      524MB   839MB  315MB   fat32           EFI system partition          boot, esp
 3      839MB   973MB  134MB                   Microsoft reserved partition  msftres
 4      973MB   205GB  204GB   ntfs            Basic data partition          boot, esp
 8      423GB   472GB  48,6GB  ext4
 9      472GB   476GB  3847MB  linux-swap(v1)
 5      476GB   476GB  489MB   ntfs                                          hidden, diag
 6      476GB   499GB  22,7GB  ntfs            Basic data partition          hidden, diag
 7      499GB   500GB  1074MB  fat32           Basic data partition          hidden, diag
UPDATE:
I have used boot-repair (comment from s1ns3nt) and Windows Boot Manager now works, but trying to boot Windows 10 (from Windows Boot Manager) returns me to grub! My boot order is:
BootCurrent: 0001
Timeout: 1 seconds
BootOrder: 0001,0000,0002
Boot0000* Windows Boot Manager
Boot0001* ubuntu
Boot0002* ubuntu
I am not sure what Boot0002* ubuntu is. I am also not sure what the star (*) means.
PyotrK
  • 45
Installing and running boot-repair and making sure that there is no "boot" flag (in gparted) fixed it. Everything boots correctly.
PyotrK
  • 45
