After upgrading Ubuntu from 14.04 to 16.04 I'm having some issues with my wifi connection.
Check this out, from a wired connection (pay attention to response delay).
leo@nelson:~$ ping facebook.com
PING facebook.com (66.220.158.68) 56(84) bytes of data.
64 bytes from edge-star-mini-shv-07-frc3.facebook.com (66.220.158.68): icmp_seq=1 ttl=75 time=154 ms
64 bytes from edge-star-mini-shv-07-frc3.facebook.com (66.220.158.68): icmp_seq=2 ttl=75 time=155 ms
64 bytes from edge-star-mini-shv-07-frc3.facebook.com (66.220.158.68): icmp_seq=3 ttl=75 time=155 ms
64 bytes from edge-star-mini-shv-07-frc3.facebook.com (66.220.158.68): icmp_seq=4 ttl=75 time=154 ms
64 bytes from edge-star-mini-shv-07-frc3.facebook.com (66.220.158.68): icmp_seq=5 ttl=75 time=155 ms
64 bytes from edge-star-mini-shv-07-frc3.facebook.com (66.220.158.68): icmp_seq=6 ttl=75 time=155 ms
64 bytes from edge-star-mini-shv-07-frc3.facebook.com (66.220.158.68): icmp_seq=7 ttl=75 time=155 ms
64 bytes from edge-star-mini-shv-07-frc3.facebook.com (66.220.158.68): icmp_seq=8 ttl=75 time=156 ms
64 bytes from edge-star-mini-shv-07-frc3.facebook.com (66.220.158.68): icmp_seq=9 ttl=75 time=156 ms
64 bytes from edge-star-mini-shv-07-frc3.facebook.com (66.220.158.68): icmp_seq=10 ttl=75 time=162 ms
64 bytes from edge-star-mini-shv-07-frc3.facebook.com (66.220.158.68): icmp_seq=11 ttl=75 time=154 ms
64 bytes from edge-star-mini-shv-07-frc3.facebook.com (66.220.158.68): icmp_seq=12 ttl=75 time=154 ms
64 bytes from edge-star-mini-shv-07-frc3.facebook.com (66.220.158.68): icmp_seq=13 ttl=75 time=155 ms
^C
--- facebook.com ping statistics ---
13 packets transmitted, 13 received, 0% packet loss, time 12001ms
rtt min/avg/max/mdev = 154.211/155.791/162.531/2.067 ms
But when I switch to WiFi:
64 bytes from edge-star-mini-shv-07-frc3.facebook.com (66.220.158.68): icmp_seq=1 ttl=79 time=323 ms
64 bytes from edge-star-mini-shv-07-frc3.facebook.com (66.220.158.68): icmp_seq=2 ttl=79 time=361 ms
64 bytes from edge-star-mini-shv-07-frc3.facebook.com (66.220.158.68): icmp_seq=3 ttl=79 time=1008 ms
64 bytes from edge-star-mini-shv-07-frc3.facebook.com (66.220.158.68): icmp_seq=4 ttl=79 time=652 ms
64 bytes from edge-star-mini-shv-07-frc3.facebook.com (66.220.158.68): icmp_seq=5 ttl=79 time=999 ms
64 bytes from edge-star-mini-shv-07-frc3.facebook.com (66.220.158.68): icmp_seq=6 ttl=79 time=1010 ms
64 bytes from edge-star-mini-shv-07-frc3.facebook.com (66.220.158.68): icmp_seq=7 ttl=79 time=1003 ms
64 bytes from edge-star-mini-shv-07-frc3.facebook.com (66.220.158.68): icmp_seq=8 ttl=79 time=1008 ms
64 bytes from edge-star-mini-shv-07-frc3.facebook.com (66.220.158.68): icmp_seq=9 ttl=79 time=420 ms
64 bytes from edge-star-mini-shv-07-frc3.facebook.com (66.220.158.68): icmp_seq=10 ttl=79 time=266 ms
64 bytes from edge-star-mini-shv-07-frc3.facebook.com (66.220.158.68): icmp_seq=11 ttl=79 time=168 ms
64 bytes from edge-star-mini-shv-07-frc3.facebook.com (66.220.158.68): icmp_seq=12 ttl=79 time=1009 ms
64 bytes from edge-star-mini-shv-07-frc3.facebook.com (66.220.158.68): icmp_seq=13 ttl=79 time=1005 ms
64 bytes from edge-star-mini-shv-07-frc3.facebook.com (66.220.158.68): icmp_seq=14 ttl=79 time=471 ms
^C
14 packets transmitted, 14 received, 0% packet loss, time 13028ms
rtt min/avg/max/mdev = 168.777/693.596/1010.408/329.180 ms, pipe 2
I have 2 different internet providers with 2 different routers on the same place. It happens the same over both connections. I've also tried with other computer with Ubuntu 12.04 and works like a charm.
I'm having this problem since I installed 16.04
Aditional info: I've been using a wired connection to work because It's unusable over wifi... BUT from time to time (every ~20-30 minutes) the wired connection gets disconnected (it happens with both routers from differents ISPs I have).
Mi wireless card info:
leo@nelson:~$ sudo lshw -class network
sudo: imposible resolver el anfitrión nelson
[sudo] password for leo:
*-network
descripción: Ethernet interface
producto: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
fabricante: Realtek Semiconductor Co., Ltd.
id físico: 0
información del bus: pci@0000:01:00.0
nombre lógico: eth0
versión: 06
serie: 4c:72:b9:58:9c:95
tamaño: 100Mbit/s
capacidad: 1Gbit/s
anchura: 64 bits
reloj: 33MHz
capacidades: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
configuración: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=full firmware=rtl8168e-3_0.0.4 03/27/12 ip=192.168.0.18 latency=0 link=yes multicast=yes port=MII speed=100Mbit/s
recursos: irq:28 ioport:e000(size=256) memoria:d0004000-d0004fff memoria:d0000000-d0003fff
*-network
descripción: Interfaz inalámbrica
producto: RT5390 Wireless 802.11n 1T/1R PCIe
fabricante: Ralink corp.
id físico: 0
información del bus: pci@0000:02:00.0
nombre lógico: wlan0
versión: 00
serie: 20:10:7a:8e:3d:66
anchura: 32 bits
reloj: 33MHz
capacidades: pm msi pciexpress bus_master cap_list ethernet physical wireless
configuración: broadcast=yes driver=rt2800pci driverversion=4.4.0-34-generic firmware=0.34 ip=192.168.1.157 latency=0 link=yes multicast=yes wireless=IEEE 802.11bgn
recursos: irq:17 memoria:fea00000-fea0ffff
As @chili555 asked, here is "dmesg | grep rt2" output
leo@nelson:~$ dmesg | grep rt2
[ 14.104800] rt2800pci 0000:02:00.0: enabling device (0000 -> 0002)
[ 14.105008] ieee80211 phy0: rt2x00_set_rt: Info - RT chipset 5390, rev 0502 detected
[ 14.109544] ieee80211 phy0: rt2x00_set_rf: Info - RF chipset 5390 detected
[ 78.812904] ieee80211 phy0: rt2x00lib_request_firmware: Info - Loading firmware file 'rt2860.bin'
[ 79.015681] ieee80211 phy0: rt2x00lib_request_firmware: Info - Firmware detected - version: 0.34
[ 105.903521] ieee80211 phy0: rt2x00queue_flush_queue: Warning - Queue 2 failed to flush
[ 106.351522] ieee80211 phy0: rt2x00queue_flush_queue: Warning - Queue 2 failed to flush
[ 106.799553] ieee80211 phy0: rt2x00queue_flush_queue: Warning - Queue 2 failed to flush
[ 107.247543] ieee80211 phy0: rt2x00queue_flush_queue: Warning - Queue 2 failed to flush
[ 107.759574] ieee80211 phy0: rt2x00queue_flush_queue: Warning - Queue 2 failed to flush
[ 108.211584] ieee80211 phy0: rt2x00queue_flush_queue: Warning - Queue 2 failed to flush
[ 108.727599] ieee80211 phy0: rt2x00queue_flush_queue: Warning - Queue 2 failed to flush
[ 109.555615] ieee80211 phy0: rt2x00queue_flush_queue: Warning - Queue 2 failed to flush
[ 148.965666] ieee80211 phy0: rt2x00queue_flush_queue: Warning - Queue 2 failed to flush
[ 149.413726] ieee80211 phy0: rt2x00queue_flush_queue: Warning - Queue 2 failed to flush
[ 149.925810] ieee80211 phy0: rt2x00queue_flush_queue: Warning - Queue 2 failed to flush
[ 150.777953] ieee80211 phy0: rt2x00queue_flush_queue: Warning - Queue 2 failed to flush
[ 367.323945] ieee80211 phy0: rt2x00queue_flush_queue: Warning - Queue 2 failed to flush
[ 368.171986] ieee80211 phy0: rt2x00queue_flush_queue: Warning - Queue 2 failed to flush
[ 368.944044] ieee80211 phy0: rt2x00queue_flush_queue: Warning - Queue 2 failed to flush
[ 369.448049] ieee80211 phy0: rt2x00queue_flush_queue: Warning - Queue 2 failed to flush
[ 469.630931] ieee80211 phy0: rt2x00queue_flush_queue: Warning - Queue 2 failed to flush
[ 470.478973] ieee80211 phy0: rt2x00queue_flush_queue: Warning - Queue 2 failed to flush
[ 470.931053] ieee80211 phy0: rt2x00queue_flush_queue: Warning - Queue 2 failed to flush
[ 471.387076] ieee80211 phy0: rt2x00queue_flush_queue: Warning - Queue 2 failed to flush
[ 471.843081] ieee80211 phy0: rt2x00queue_flush_queue: Warning - Queue 2 failed to flush
[ 472.291140] ieee80211 phy0: rt2x00queue_flush_queue: Warning - Queue 2 failed to flush
[ 472.739165] ieee80211 phy0: rt2x00queue_flush_queue: Warning - Queue 2 failed to flush
[ 473.191144] ieee80211 phy0: rt2x00queue_flush_queue: Warning - Queue 2 failed to flush
[ 473.691199] ieee80211 phy0: rt2x00queue_flush_queue: Warning - Queue 2 failed to flush
[ 474.191255] ieee80211 phy0: rt2x00queue_flush_queue: Warning - Queue 2 failed to flush
[ 1191.044092] ieee80211 phy0: rt2x00queue_flush_queue: Warning - Queue 2 failed to flush
[ 1191.816158] ieee80211 phy0: rt2x00queue_flush_queue: Warning - Queue 2 failed to flush
[ 1192.316182] ieee80211 phy0: rt2x00queue_flush_queue: Warning - Queue 2 failed to flush
[ 4549.926258] ieee80211 phy0: rt2x00queue_flush_queue: Warning - Queue 2 failed to flush
[ 5030.979039] ieee80211 phy0: rt2x00queue_flush_queue: Warning - Queue 2 failed to flush
[ 5031.427145] ieee80211 phy0: rt2x00queue_flush_queue: Warning - Queue 2 failed to flush
[ 5031.883092] ieee80211 phy0: rt2x00queue_flush_queue: Warning - Queue 2 failed to flush
[ 5032.655142] ieee80211 phy0: rt2x00queue_flush_queue: Warning - Queue 2 failed to flush
[ 7430.737637] ieee80211 phy0: rt2x00queue_flush_queue: Warning - Queue 2 failed to flush
[ 7431.185659] ieee80211 phy0: rt2x00queue_flush_queue: Warning - Queue 2 failed to flush
[ 7432.033748] ieee80211 phy0: rt2x00queue_flush_queue: Warning - Queue 2 failed to flush
[ 7432.497744] ieee80211 phy0: rt2x00queue_flush_queue: Warning - Queue 2 failed to flush
[ 7432.997769] ieee80211 phy0: rt2x00queue_flush_queue: Warning - Queue 2 failed to flush
[ 7433.497799] ieee80211 phy0: rt2x00queue_flush_queue: Warning - Queue 2 failed to flush
[10551.963800] ieee80211 phy0: rt2x00queue_flush_queue: Warning - Queue 2 failed to flush
Added iwconfig requested by Jeremy31
nelson@nelson:~$ iwconfig
lo no wireless extensions.
eno1 no wireless extensions.
enp0s19f2u5 no wireless extensions.
wlp2s0 IEEE 802.11bgn ESSID:"Liit"
Mode:Managed Frequency:2.462 GHz Access Point: 54:BE:F7:61:84:25
Bit Rate=11 Mb/s Tx-Power=20 dBm
Retry short limit:7 RTS thr:off Fragment thr:off
Power Management:on
Link Quality=43/70 Signal level=-67 dBm
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:1637 Invalid misc:528 Missed beacon:0
