How do I reinstall Windows 10 while keeping my dual boot configuration? I want to do a clean install of Windows 10. I have Ubuntu 16.04. I upgraded from Windows 7 to Windows 10.
Thanks
The problem in this situation is that, if you install Windows 10, it will overwrite the MBR. Windows thinks it's the only OS in the world.
  • Install Windows using Windows installation media.
  • Boot using an Ubuntu Live CD. Choose the "Try Ubuntu" option.
  • Open a terminal and type sudo grub-install /dev/sdX where sdX is your hard drive. The first hard drive is called sda, so if you only have one hard drive, replace sdX with sda.
  • Press . After the command is executed run sudo update-grub
  • After the command is executed, reboot your system and remove the live CD or USB when asked to in order to prevent booting into it.
  • Voila! You will have grub restored with both OSes.
Tobias Feil
  • 167
Ceda EI
  • 2,070
