I got a pop-up for a security update which uninstalled and reinstalled lots of stuff. During this it said something failed to update. Now when I try to install the update that failed I get this error message.
Check if you are using third party repositories. If so disable them, since they are a common source of problems. Furthermore run the following command in a Terminal: apt-get install -f
Running the command gives me this
Could not open lock file /var/lib/dpkg/lock - open (13: Permission denied)
Unable to lock the administration directory (/var/lib/dpkg/), are you root?
I barely know anything about linux so please give simple answers and don't use shorthand lingo.
Edit: I ran the command with sudo and got this in terminal
The following package was automatically installed and is no longer required:
libllvm3.5
Use 'apt-get autoremove' to remove it.
The following extra packages will be installed:
libllvm3.8v4
The following NEW packages will be installed:
libllvm3.8v4
0 upgraded, 1 newly installed, 0 to remove and 9 not upgraded.
33 not fully installed or removed.
Need to get 0 B/10.2 MB of archives.
After this operation, 40.3 MB of additional disk space will be used.
Do you want to continue? [Y/n] y
(Reading database ... 788253 files and directories currently installed.)
Preparing to unpack .../libllvm3.8v4_1%3a3.8-2ubuntu3~trusty4_i386.deb ...
Unpacking libllvm3.8v4:i386 (1:3.8-2ubuntu3~trusty4) ...
dpkg: error processing archive /var/cache/apt/archives/libllvm3.8v4_1%3a3.8-2ubuntu3~trusty4_i386.deb (--unpack):
trying to overwrite '/usr/lib/i386-linux-gnu/libLLVM-3.8.so.1', which is also in package libllvm3.8:i386 1:3.8~+rc3-1~exp1~gd~t
dpkg-deb: error: subprocess paste was killed by signal (Broken pipe)
Side note: I can't launch the Ubuntu software center and everytime I launch steam. Steam brings up the terminal and installs something every time it didn't used to do that.
