I have the following setup :
Filesystem 1K-blocks Used Available Use% Mounted on
udev 1009440 4 1009436 1% /dev
tmpfs 205004 1076 203928 1% /run
/dev/sda1 10189112 8848004 800488 92% /
none 4 0 4 0% /sys/fs/cgroup
none 5120 0 5120 0% /run/lock
none 1025016 72 1024944 1% /run/shm
none 102400 4 102396 1% /run/user
/dev/sdb1 20510332 9607008 9838416 50% /media/poloextra
I would like to make use of some of the space on /dev/sdb1 to install more programmes (using apt-get). What's the best way to do this ?
In the past, and when I've only been interested in data, I've created a directory in, for instance the root like this /mydatadir, and then created a symbolic link from there into the file system with more room.
I'm just not sure how to apply that idea to getting more space for installing software ? Or maybe there is a better approach ?
