I tried to install teamviewer. so I followed the step in Installed Teamviewer using a 64-bits system, but I get a dependency error.
However, I could not install libsm6:i386...
wooruang@wooruang-desktop:~/Downloads$ sudo apt-get install libsm6:i386
Reading package lists... Done
Building dependency tree
libsm6:i386 : Depends: libuuid1:i386 (>= 2.16) but it is not going to be installed
this is the result message.
so I tried to install libuuid1:i386, but it required another dependencies over and over again...
Could you please tell me what should I do ?
You could try enabling the i386 architecture with this command:
sudo dpkg --add-architecture i386
Then update/upgrade packages:
sudo apt-get update
sudo apt-get dist-upgrade
and try to install libsm again.
Ryan_DS
  • 103
polle
  • 336
