22
On Ubuntu 16.04 I am getting the following error:
$ openconnect -v vpn.com
POST https://vpn.com/
Attempting to connect to server 1.1.1.1:443
SSL negotiation with vpn.com
Connected to HTTPS on vpn.com
Got HTTP response: HTTP/1.1 200 OK
Content-Type: text/html; charset=utf-8
Transfer-Encoding: chunked
Cache-Control: no-cache
Pragma: no-cache
Connection: Keep-Alive
Date: Mon, 22 Aug 2016 00:04:14 GMT
X-Frame-Options: SAMEORIGIN
X-Aggregate-Auth: 1
HTTP body chunked (-2)
XML POST enabled
Error: Server asked us to run CSD hostscan.
You need to provide a suitable --csd-wrapper argument.
Failed to obtain WebVPN cookie
I tried --no-xmlpost post and got error as well.
Here is some background:
I had Ubuntu 14.04 and was connecting to vpn server using openconnect. Then a week ago, it stopped working with this issue. My guess is that the vpn site upgraded its Cisco vpn server to required to CSD trojan. Anyhow, I decided to upgrade to 16.04 and still have the same problem.
abu_bua
  • 11,313
sdstack
  • 479
I found my answer through this post:
https://gist.github.com/l0ki000/56845c00fd2a0e76d688
I did the following:
cd ~
mkdir .cisco
cd .cisco
wget https://gist.githubusercontent.com/l0ki000/56845c00fd2a0e76d688/raw/61fc41ac8aec53ae0f9f0dfbfa858c1740307de4/csd-wrapper.sh
chmod +x csd-wrapper.sh
Edit the file with the vpn server:
CSD_HOSTNAME=vpnserver.com
Run the file
./csd-wrapper.sh
Run openconnect:
sudo openconnect --csd-user=YOURLINUXUSERNAME --csd-wrapper=/home/YOURLINUXUSERNAME/.cisco/csd-wrapper.sh vpnserver.com
Maura
  • 143
sdstack
  • 479
I found that I needed to specify --os=win as well. This seemed to work around a 404 response that the server was generating when attempting to download sfinst.
GET https://vpn.company.com/CACHE/sdesktop/install/binaries/sfinst
Got HTTP response: HTTP/1.1 404 Not Found (does not exist)
Information on the 404 for sfinst issue can be found on the openconnect-devel mailing list "Connecting with Linux when the CSD is available" post.
I had success with the following command which uses the os flag and the csd-wrapper flag together:
sudo openconnect \
    --user <USERNAME> \
    --cert-expire-warning=15 \
    --certificate <CERTFILE> \
    --os=win \
    --csd-user=<USERNAME> \
    --csd-wrapper=<PATHTO>/csd-wrapper.sh \
    https://<VPNADDRESS e.g., vpn.company.com>
D.A.
  • 167
I had this Error in Ubuntu 18.04
I was able to connect to the server using the link below and the second answer.
just use the -v flag
sudo openconnect -v NAMESERVER.COM
abu_bua
  • 11,313
