24
I have created a desktop icon for the gddccontrol, but to run it I need to execute it from sudo. Is there a way to run a command from the desktop icon like,
sudo -pPASSWORD gddccontrol
so it won't ask me for the password in the terminal?
I just want click and run it with sudo permissions.
[Desktop Entry]
Type=Application
Name=GDDCControl
Terminal=false
Comment=gddccontrol ddccontrol
Exec=sudo -pPASSWORD gddccontrol
Icon=~/Pictures/10429.png
When I run the icon from the terminal with the following Exec command it works good, but it doesn't work in Launcher :(
Exec=echo mypasswd | sudo -S gddccontrol
Eugene
  • 351
5 Answers5
25
NEVER EVER use your password, stored in a .desktop file. It is terribly unsafe.
Furthermore, you cannot run complicated commands in a .desktop file just like that, but that is another subject.
What to do
You have a few options:
  1. Add gddccontrol to the sudoers file, as explained e.g. here. This can be done if you are sure the application cannot be used to do maliceous things.
    Then use
    Exec=sudo gddccontrol
    in the Exec=-line
  2. Another option is to replace the Exec= line by:
    Exec=gksu gddccontrol
    In this case, once you click the icon, you will be prompted to enter your password via gui.
    You possibly need to install gksu:
    sudo apt-get install gksu
Jacob Vlijm
  • 85,475
Using sudo will by definition prompt a password request. What you need to do is to grant execute permissions to your user. I'm not sure where that program is located, but for the sake of this answer, let's assume it is /usr/bin/.
In a terminal run this:
sudo chmod o+x /usr/bin/gddccontrol
That command is granting other users (like you) the right to execute the program without need for permission.
Then, in the .desktop file, just use:
Exec=gddccontrol
Open your terminal and run this command
cd /usr/share/applications
After that run this command
sudo gedit application.desktop
and copy and paste the following for x64 bit machines
#!/usr/bin/env xdg-open
[Desktop Entry]
Version=1.0
Type=Application
Terminal=false
Icon[en_US]=/opt/lampp/htdocs/favicon.ico
Exec=sudo /opt/lampp/manager-linux-x64.run
Comment[en_US]=start xampp manager
Name[en_US]=xampp
Name=xampp
Comment= start xampp application
Replace
with the path of the application you want to launch for my case it is xampp manager
Replace
with the path of your application icon.
Save the file and run this command below
sudo visudo
Add the following line at the end of your file
<your-username> ALL = NOPASSWD: <path of application>
Type your user name and paste the path of your application without including the angle brackets like this
nelson ALL = NOPASSWD: /opt/lampp/manager-linux-x64.run
Save the file and check your applications it's there.
Hope this helps.
As an alternative, if you don't mind typing in your password, but just want the shortcut to run the application, you can just set terminal=true in the .desktop file and then it will open a terminal to prompt you.
This solution was all I needed to create a shortcut to run a simple command with options I could never remember. Now it's just double-click and enter my password.
Jivers
I am against hard-coding password in a plain text file so I can think of two possible solutions:
  1. make a system-wide edit that every command issued by your user with sudo is ran as superuser without prompting for password. You can find out how in this answer
  2. If you dont want sudo commands to always be executed with password prompt, best practice use gksu before your command to prompt for password in a graphic window rather than writing your raw password in a file.
