I Just Update ubuntu When I turn on the computer usually goes to rEFInd screen, which gives me the option to choose OSx and Ubuntu. Initially, I could click in any of them and they will boot directly to Ubuntu.
Please help ...
Chances are the update (re-)installed GRUB, which has overridden rEFInd. This issue is covered in the rEFInd documentation, on the page entitled "Keeping rEFInd Booting." That page covers several recovery options. Since you don't say to what (if any) OS you can boot right now, I can't be more precise in my answer here. If the system isn't booting at all, then I recommend you download the USB flash drive or CD-R image of rEFInd from its downloads page, prepare that boot medium, and use it to boot to OS X or Ubuntu to fix the problem. Alternatively, you may be able to boot into OS X by holding down the Option (or Alt) key while you power on the system, from where you can fix the problem.
Rod Smith
  • 45,120
  • 66
  • 108
You can use this link to dual boot without rEFInd, David Anderson's answer (btw thanks!). After a kernel-update I needed to do update-grub, and then repeat the process from ElCapitan. This solution needs a grub-install, of course...
