I had downloaded the source code of GNU octave and had installed it using make install. However, the installation had some error, due to which it could not open the GUI on launching octave.
For this reason I wanted to un-install the package.
For un-installing, I opened the software center. There in installed packages list, I could see GNU octave enlisted. On clicking on remove button, nothing happens.
Hence I tried to uninstall the package from command prompt using
sudo apt-get remove octave
sudo apt-get autoremove octave
Still octave did not disappear from /usr/local/bin folder. So, I manually deleted it using:
sudo rm -rf /usr/local/bin/octave
sudo rm -rf /usr/local/lib/octave
Now when I again go back to software center, GNU octave is still enlisted as installed software.
I want to install it again, properly. For which I want to completely remove the previous installation.
My questions are:
  1. What else is required to completely remove octave
  2. How to correctly install it so that I can use its GUI efficiently
Note: the octave version is 4.0.1 Ubuntu version - 16.04 LTS
Zanna
  • 72,312
Gauri
Gauri. I just successfully uninstalled Octave from my ubuntu 16.04 according to the solutions at http://installion.co.uk/ubuntu/xenial/universe/o/octave/uninstall/index.html.
I saw something is wrong in your code sudo apt-get autoremove octave. The right way should be sudo apt-get remove --auto-remove octave. Perhaps you could try it out and see if my suggestion works. Good luck!
Kaz Wolfe
  • 34,680
Liz
  • 31
If you installed Octave through the ./configure && make && sudo make install process from source code, you can uninstall by entering the build directory where you ran sudo make install, and running this command:
sudo make uninstall
EDIT: This is true as of version 3.8.0 because it has an uninstall rule in its Makefile. Please check if your version has the same, or similar, rule.
In order to determine whether such a rule exists, open up the Makefile of the version of Octave source code you have downloaded, and look for the string uninstall:. If so, it means you have an uninstall rule, and that you can run make uninstall.
This Ask Ubuntu answer is the source of this information
Zanna
  • 72,312
