It looks like I totally blew my boot menu to bits while I was trying to update it after removing two unknown partitions left from a previous ubuntu installation with live usb. I accidentally sent the grub to sdc instead of sda and now the computer can't find the partition list. Sda1 is misplaced, but not gone, and sda6 is Ubuntu 16.04. I thought I could get the grub back by reinstalling Ubuntu 14.04, but it unmounted Windows before I could stop it. All I get is minimal bin-bash grub if I start it up normally. I have to use a live usb with 14.04 because I corrupted the 16.04 drive I was using when I screwed up. Is there a way to save this disaster so that I can at least start it up again? I would very much appreciate any help. Here's an idea of what's going on:
ubuntu@ubuntu:~$ sudo blkid -o list
device     fs_type label    mount point    UUID
/dev/loop0 squashfs         /rofs
/dev/sda1  ntfs    PQSERVICE (not mounted) DE221B70221B4CC1
/dev/sda2  ntfs    SYSTEM RESERVED (not mounted) 4CF01BBFF01BAE68
/dev/sda3  ntfs    Acer     (not mounted)  08EA1D44EA1D3004
/dev/sda5  swap             <swap>         e9ad90ad-f73a-49b0-           b3fb-a4ae29b3aac7
/dev/sda6  ext4             (not mounted)  7021ee40-917c-4354-8fce-01e3cf0f1858
/dev/sdb1  vfat    UBUNTU 1404 /cdrom      8699-B94C
ubuntu@ubuntu:~$ sudo mount /dev/sda6 /mnt
\ubuntu@ubuntu:~$ sudo mount --bind /dev /mnt/dev &&
> sudo mount --bind /proc /mnt/proc &&
> sudo mount --bind /sys /mnt/sys
ubuntu@ubuntu:~$ sudo chroot /mnt
root@ubuntu:/# grub-install /dev/sda
Installing for i386-pc platform.
/proc/devices: fopen failed: No such file or directory
device node not found
grub-install: warning: Sector 18 is already in use by the program`Acer    registration utility (?)'; avoiding it.  This software may cause boot or  other problems in future.  Please ask its authors not to store data in the boot track.
grub-install: warning: Sector 32 is already in use by the program    `FlexNet'; avoiding it.  This software may cause boot or other problems in  future.  Please ask its authors not to store data in the boot track.
Installation finished. No error reported.
root@ubuntu:/#
ubuntu@ubuntu:~$ df
Filesystem     1K-blocks     Used Available Use% Mounted on
    /cow             2888496    81328   2807168   3% /
    /dev             2877008       12   2876996   1% /mnt/dev
    tmpfs             577700     1288    576412   1% /run
    /dev/sdb1        7801432  1046440   6754992  14% /cdrom
    /dev/loop0        975872   975872         0 100% /rofs
    none                   4        0         4   0% /sys/fs/cgroup
    tmpfs            2888496     1072   2887424   1% /tmp
    none                5120        4      5116   1% /run/lock
    none             2888496       80   2888416   1% /run/shm
    none              102400       84    102316   1% /run/user
    /dev/sda6      118658332 11728020 100879752  11% /mnt
ubuntu@ubuntu:~$ sudo parted -ls  # ... space minus ell ess
Model: ATA WDC WD6400BEVT-2 (scsi)
Disk /dev/sda: 640GB
Sector size (logical/physical): 512B/512B
Partition Table: msdo
Number  Start   End     Size    Type      File system     Flags
     1      1049kB  15.0GB  15.0GB  primary   ntfs            diag
     2      15.0GB  15.1GB  105MB   primary   ntfs            boot
     3      15.1GB  249GB   234GB   primary   ntfs
     4      249GB   640GB   391GB   extended
     6      249GB   373GB   124GB   logical   ext4
     5      373GB   379GB   6091MB  logical   linux-swap(v1)
Model: SanDisk Cruzer Glide (scsi)
Disk /dev/sdb: 8004MB
Partition Table: msdos
     1      16.4kB  8004MB  8004MB  primary  fat32        boot
ubuntu@ubuntu:~$ sudo lsblk -fm
NAME   FSTYPE   LABEL           MOUNTPOINT NAME     SIZE OWNER GROUP MODE
    sda                                        sda    596.2G root  disk  brw-rw----
    ├─sda1 ntfs     PQSERVICE                  ├─sda1    14G root  disk  brw-rw----
    ├─sda2 ntfs     SYSTEM RESERVED            ├─sda2   100M root  disk  brw-rw----
    ├─sda3 ntfs     Acer                       ├─sda3 218.1G root  disk  brw-rw----
    ├─sda4                                     ├─sda4     1K root  disk  brw-rw----
    ├─sda5 swap                     [SWAP]     ├─sda5   5.7G root  disk  brw-rw----
    └─sda6 ext4                     /mnt       └─sda6 115.1G root  disk  brw-rw----
    sdb                                        sdb      7.5G root  disk  brw-rw----
    └─sdb1 vfat     UBUNTU 1404     /cdrom     └─sdb1   7.5G root  disk  brw-rw----
    sr0                                        sr0     1024M root  cdrom brw-rw----
    loop0  squashfs                 /rofs      loop0    953M root  disk  brw-rw----
ubuntu@ubuntu:~$ ls -F /boot/grub
gfxblacklist.txt  grubenv
ubuntu@ubuntu:~$ sudo mount /dev/sda1 /mnt
The disk contains an unclean file system (0, 0).
Metadata kept in Windows cache, refused to mount.
Failed to mount '/dev/sda1': Operation not permitted
The NTFS partition is in an unsafe state. Please resume and shutdown
Windows fully (no hibernation or fast restarting), or mount the volume
read-only with the 'ro' mount option.
John
  • 35
Problem solved. I wiped out the disk and reinstalled Ubuntu. Though I lost Windows and everything else, the computer works fine now. I learned to never ever mess with anything that might affect grub. Just leave those unknown partitions alone...
John
  • 35
